Sponsored by:
Sponsored by:
AC sprays water from center and only hot air from sides '97A8Q
Old 02-17-2014, 01:27 PM
hyperlogos's Avatar
Default AC sprays water from center and only hot air from sides '97A8Q
Subject pretty much says it all. If I set both sides to lo then I get hot air out of everywhere but the center, where I get cool air and eventually little bits of water. Never sounds like running water, though, or splashing. I'm suspecting icing and that the heater valve is never switching off. Do I just need a vag-com to figure this one out, or do I just rebuild or replace something?
Old 02-17-2014, 01:46 PM
silverd2's Avatar
I'd start by cleaning the interior AC drains...the always seem to clog eventually...that could be the source of the "spray".
http://www.audipages.com/Tech_Articl...tordrains.html
The cool/hot air maybe totally unrelated to the spray ...it may just need a recharge (top off) of refrigerant and/or a VagCom scan for codes (temp flaps/motors, etc...).
Low on refrigerant in these cars usually starts with driver's side (LHD) blowing much warmer than passengers side...worse as refrigerant level goes down.
http://forums.quattroworld.com/a8/msgs/15213.phtml
A VagCom scan will tell you a lot.
Old 02-17-2014, 02:10 PM
hyperlogos's Avatar
Well, I will check the drains, but I get FULL HOT air out of everywhere but the center, and I get semi-cooled air from the center. Pretty sure the AC is actually working, and I'm not asking for ANY hot air, so clearly there is something bananas
IntheQ5
Q5/SQ5 MKI (8R) Discussion
37
08-28-2023 11:37 PM
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
raiderrider
12
09-08-2015 05:46 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
Quick Reply: AC sprays water from center and only hot air from sides '97A8Q
