Sponsored by:
Sponsored by:
Audi A8 transmission problem
Old 11-27-2015, 04:26 PM
Kirk Harding's Avatar
Default Audi A8 transmission problem
Just bought a high milage 1999 a8 Quattro, a mint example minus an oil leak....... and the abs ligh........and the airbag light that just appeared.
And now this this morning i noticed when i put it in reverse it didnt have that pull so when you release the brakes it moves but that went away immediately. And i just got home after a 45 min round trip and it just clunks at a stop light and all the gears light up and it feels like its in a higher gear(limp mode??). And a check engine light appears.
If i turn the car off it will work until i give it some gas and clunk same thing. Tell me its a $20 dollar fix and its will resolve my othe rissues too.
But in all seriousness any help would be greatly appreciated.
Old 11-28-2015, 02:19 AM
twentysevenlitres's Avatar
You need a VCDS scan to define the issues a bit more.
ABS issue could be a sensor, but the early Bosch 6.3 modules had a reputation for failure (cheapish repair at one of many electronic repair shops (BBA Reman or check ebay "Bosch 6.3 repair")).
Airbag light could be the coil spring on the steering wheel, but again a scan is in order to know more.
The transmission could simply be low oil, or it could be a fault with the valve body (common with this transmission).
If it is the valve body, an early diagnosis could prevent further transmission damage.
Again, scan it or take it to a ZF specialist (Tozo's shop (TozoM8) if you're anywhere near him (Chicago?)).
Old 11-28-2015, 03:37 AM
Thanks for the info whatever broke did so suddenly, i just checked it again hoping it would work now its cooled down but to no avail. What codes should i be looking for if it's the valve? Im in Ontario, Canada btw.
Old 11-28-2015, 02:03 PM
The codes the transmission can throw range from P0700/17084 to P0790/17174.
P0700 to P0708 can indicate a selector switch (F125) fault. P0730 or higher can indicate other hydraulic or actuator faults.
The valve body is the primary manifold in the transmission which selects the fluid pathways to choose the right gear. My understanding is the manifold can crack.
In this circumstance, if you're lucky the valve body can be replaced. However, oil starvation can cause seal damage elsewhere in the transmission which will then require a rebuild. Either way you'll need to break out the cheque book!
But you need to take it somewhere that can properly diagnose it.
Old 12-02-2015, 04:37 PM
These are the codes i pulled
Size:  61.8 KB Name:  20151202_202623_zpsga3ywipy.jpg
Old 12-03-2015, 10:56 AM
tozoM8's Avatar
Default If the reverse is fine then you need a rebuild.
It is a bummer, but the couch A is gone.
Old 12-03-2015, 03:22 PM
Couch A?
Old 12-03-2015, 03:24 PM
Also if i were to look for a replacement tranny what other models could i look for.
Old 12-03-2015, 07:42 PM
tozoM8's Avatar
Default Clutch A.
Autocorrect got me. Any A8Q trans would work. Later is better.
Couch A?
babins4
07-04-2009 06:42 AM
Audimobiles
05-08-2008 08:35 PM
0000audi
04-29-2007 12:26 PM
zenmasTTa
15
05-30-2005 02:59 PM
jbachert
08-03-2004 09:51 AM
Quick Reply: Audi A8 transmission problem
