Beware Cheap Car Hoists
if so - just to get it down you could measure the distance and cut off a slice of a schedule 80 pipe (1/2" or whatever you need), cut a slit in the pipe, heat it, bend it enough to clear the bolt, grease the pulley sides with a minor amount, install the fabricated bushing, then crush/push it back enough to wrap a few 3/8" strips winding around the pipe-bushing to keep it from falling off. if its wide enough a metal band pipe clamp could do the trick to.
carl viking
36
04-27-2020 01:17 PM
