Sponsored by:
Sponsored by:
Bilstein Front Struts
Old 07-09-2016, 04:02 AM
2001 S8's Avatar
Default Bilstein Front Struts
Has anybody changed out their factory front struts for Bilstein B6 Series (24066785) struts? Did the Bilsteins change the original ride height or handling?
I'm looking to change out the front struts when both front lower control arms are replaced. I'll also be changing the bump stops (KYB) and strut mounts (Sachs).
Thanks for any input.
Old 07-09-2016, 05:50 AM
LarryJa's Avatar
Since the bilsteins are high pressure gas shocks, they may affect your ride height, bumping it up a little. Do an alignment at the same time.
Old 07-09-2016, 09:18 AM
MikkiJayne's Avatar
I have Bilsteins all round, I think B8s though. The handling is sublime. I changed the springs at the same time so hard to say what they did to the ride height. IIRC the spring platform was in the same place though so it should be about the same.
Old 07-10-2016, 05:13 AM
2001 S8's Avatar
You used Bilstein B8s on an S8? Those don't even show up an an option.
Old 07-10-2016, 08:37 AM
MikkiJayne's Avatar
Hmm maybe they are B6s then? They were lightly used when I got them and I didn't check the part numbers.
Regardless, they handle very well
Old 07-10-2016, 11:38 AM
2001 S8's Avatar
Thanks for the clarification. Glad to hear you've had, so far, a good experience with them.
Old 07-12-2016, 08:14 AM
Y888's Avatar
I have bilsteins all around,i think they are firmer than oem sachs but i am not sure.
Check if your upper spring plate is cracked mine were cracked and i changed then and the strut mounts too.
Old 07-12-2016, 06:44 PM
2001 S8's Avatar
Good to know. Thanks for the advice.
Did your ride height change at all?
Old 07-12-2016, 09:57 PM
Y888's Avatar
I think it stayed the same.
Old 07-13-2016, 03:44 PM
2001 S8's Avatar
Great! I'm trying to keep my car as stock looking as possible.
Quick Reply: Bilstein Front Struts
