Sponsored by:
Sponsored by:
Brake noise, creaking, dry or worn pins?
Old 08-31-2016, 05:22 AM
jmmillerfzr's Avatar
Default Brake noise, creaking, dry or worn pins?
I started getting a creaking noise when I apply the brakes. Coming from drivers side front. Pulled the wheel and had the better half hit the brakes. It seems the noise is coming from movement between the caliper and the pins. When the brake load is applied the caliper seems to have a little movement on the pins side to side. Could the lube have dried out or excessive wear on the pins? Anyone experience this before?
Old 08-31-2016, 06:49 AM
nyrobbie77's Avatar
It sounds like the pins are dry. I would pull the pins, clean, and relube. Also lube the areas of the pads where they contact the caliper/caliper bracket. Use specified brake lubricant, NOT never-seize.
I've seen this on other makes and that's typically the fix.
Old 09-01-2016, 04:22 AM
Y888's Avatar
i washed my brand new rotors with acid based wheel cleaner and i am getting this heavy creaking noise after that but only when at a stop when releasing brakes slowly.
I guess acid ate my rotor surface and now i am gonna try new rotors and hope they solve the problem.
Old 09-01-2016, 03:58 PM
Articus's Avatar
You know, what's funny is that I noticed this on my S8 the day. Creaking when at a stop and I released the brake slowly.
I was thinking that maybe it's the firewall that is creaking since the master cylinder is mounted there. I've been told the firewall is flimsy so people have been installing a "brake block" to stop the master cylinder moving...
FYI I'm on new front and rear rotors maby 500-700 miles on them. I haven't used a wheel cleaner on the wheels yet since getting the car (shame on me).
Y888 I can't remember if i was reading here if it was you who picked up some 20" Final edition wheels (or D3 A8 W12). Got any pics?!!
Old 09-01-2016, 06:14 PM
Y888's Avatar
I'll just tease you with this one until i get them protected with ceramic coating
Sorry for off topic
Old 09-03-2016, 05:12 AM
silverd2's Avatar
Had exactly this symptom (creaking) a few months back. Had nothing to do with lube. When I took the pads out, they fell out in 2 pieces ... the friction material had separated from the metal backing.
Don't know how common my problem is (was) and don't even recall the brand of pads ... had been in there for many 10s of Ks of miles.
Yours may look OK, but disassembly exposes some odd things sometimes.
Cheers
Old 09-03-2016, 07:12 AM
Y888's Avatar
My pads are oem,got them from Jim Ellis.
Old 09-13-2016, 04:49 AM
silverd2's Avatar
The source is irrelevant ... how old are your pads? ...have you actually pulled them out for inspection?
Old 09-13-2016, 05:04 AM
Y888's Avatar
very young when they started squeaking,3k miles or 4-5 months.
I didn't pull them out but i will have to fix that problem soon.
Old 11-21-2016, 08:42 AM
Quick update on my creaking brakes, clean and lubed the pins and back of the pads and the noise is gone. While I was at it I did replace the rotors, Rockauto had some ultra rotors on discount and they seemed pretty decent and for $12 could not pass them up. I did find while doing the brakes I have a bad inner tie rod, so next project has been identified.
Also found a coolant leak, near the coolant expansion tank there is a small black cover that is behind the tank and there is a small tee that carries the coolant, it was cracked. So if you find a coolant leak on the drivers side of the car it could be this tee.
HaVoC
09-21-2007 09:58 AM
bgh
09-23-2005 01:22 PM
vass
02-27-2003 05:21 PM
Whitjr
12-04-2002 09:36 AM
kilty
01-17-2001 06:40 AM
Quick Reply: Brake noise, creaking, dry or worn pins?
