Brake pedal sinks to the floor, ABS?
#11
Here's a pic of the shoe, it does look a little worn I can't imagine that's enough to throw a code though?
https://i.imgur.com/BMNmwl5.jpg
The shoe (or lack of) is not what really throws the code. The inability of the adjuster, whether due to shoe missing (shorter throw) or internal wear of adjuster (always happens eventually) not allowing enough pressure to move fully from advanced to retarded timing position.
ALL the tension on the chain is placed there mechanically by an internal spring in the adjuster (not ever the problem), NOT oil pressure. Oil pressure simple moves the piston with entire tensioned loop of chain up and down as needed to change intake cam timing.
Thanks to no internal seals (except in center, between advance & retard chambers) , just an originally precise fit between soft metal & hard metal (wears quickly with time) these adjusters are doomed to irreparably fail...not enough oil pressure can be transmitted, thanks to leaking past pressure chambers, to push the chain loop into fully advanced position.
...therefore P0022 = over-retarded (didn't advance enough) on bank #2 driver's side.
Here's why >>>
quattroworld.com Forums: Failed 40V cam adjuster dissected...disappointingly non-rebuildable >>>
#12
Here's why >>>
Here's why >>>
I'll do an oil + filter change and take it out for a drive... maybe the oil in it is too light. I already have a pile of m1 0w-40 laying around lol
Milpitas2.7T
01-28-2007 09:26 PM
Black Sunshine
12-07-2005 05:21 PM
Scot J
06-20-2002 05:16 AM
AUDINOW AlexandriaVA
12-20-2000 11:05 AM
