Cam chain tensioner install
I'm replacing my cam chain tensioners. Does anyone have a copy of the procedure for retorquing the cams after removal? 2001 S8 by the way.
Thanks
Thanks
D2 bentley manual | Partsgeek.com
You're welcome
This might help
It is a big job. I've done both sides in separate settings. The drivers' side was most difficult. I had to pull both cams. Passenger side was a bit easier and only had to remove intake cam. Found it worn out and had to replace it due to lobe wear at ~200k miles. Car runs fantastically since both sides were done. Pulls like new!
2000 A8L AKB with 212K miles on it.
Roland
Roland
One side is 15 links sprocket to sprocket, the other bank is 16
Count em b4 you pull it apart. I forget which side is which. The reason is one tensioner is upside down from the other.
D2 AKB 4.2 Cam Position Sensor P1347 - Help!
1/9/17
All-Audi-Home
2000 A8L AKB 4.2 220K miles
Having DTC P1347 post Timing Belt change and Cam Adjuster install on the driver’s side of the 2000 A8L D2. When I did the TB I used a lock in the Speed Sensor hole and made sure I was a TDC on #1. I used the cam lock bar, as always, and got the marks 100% dead on. I set the intake and exhaust at 15 rollers spacing. Engine runs strong and smooth but I get a P1347 error as soon as the engine warms. I replaced the DS cam position sensor (again) and still get the P1347.
Here is summary of VAGCOM findings. I also monitored engine blocks 91, 92, 93 and got some strange results that I cannot decipher. In block 91 and 92 does “:Cam Ctrl. OFF” mean that I should disconnect the cam tensioners, or is that telling me that VAGCOM turned them off? I think my problem lies in the block 93 but I seek your expertise on what it means.
Help appreciated. Tx
Roland
2011 A8L 4.2
2006 A6 3.2 Avant
2000 A8L 4.2
Readiness: 0110 1101
Monday,09,January,2017,10:55:08:21918
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 16.8.4.2
Data version: 20161129 DS267.0
Ross-Tech: Home
Address 01: Engine Labels: None
Control Module Part Number: 4D0 907 560 AL
Component and/or Version: 4.2L V8/5V G01 0001
Software Coding: 06753
Work Shop Code: WSC 00000
Additional Info: WAUFL54D7YN007597 AUZ7Z0X1203111
VCID: 70EF1B3330F68DC239-5142
1 Fault Found:
17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28)
P1347 - 35-00 - Incor. Correl.
Readiness: 0010 1101
1 Fault Found:
Address 01: Engine (4D0 907 560 AL)
10:56:23 Group 091
720 /min RPM
18.8 % Load
Cam Ctrl. OFF
0.0°KW Idle Stabilization
10:56:23 Group 092
720 /min RPM
18.8 % Load
Cam Ctrl. OFF
-1.0°KW Idle Stabilization
10:56:23 Group 093
720 /min RPM
18.8 % Load
-9.0°KW Idle Stabilization
22.0°KW Idle Stabilization
Chassis Type: 4D (4D - Audi A8 D2 (1994 > 2003))
Scan: 25 01 03 08 11 15 16 17 18 35 37 45 55 56 57 65 67 75 76 77
02
VIN: WAUFL54D7YN007597
Part No: 4D0 907 560 AL
Component: 4.2L V8/5V G01 0001
Coding: 06753
Shop #: WSC 00000
1 Fault Found:
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4D0 907 389 E
Component: ABS/ESP allrad D26
Coding: 08397
Shop #: WSC 02314
VCID: 3169DE37FB7CC4CA76-5142
No fault code found.
Address 08: Auto HVAC Labels: 4D0-820-043-MYX.lbl
Part No: 4D0 820 043 Q
Component: A8-Klimavollautomat D13
Coding: 00180
Shop #: WSC 08376
VCID: 2A5BC95BD6AAB712B7-2588
Address 15: Airbags Labels: 4D0-959-655-AI8.lbl
Part No: 4D0 959 655 P
Component: Airbag Front+Kopf 1000
Coding: 00427
Shop #: WSC 02324
VCID: 3F8D880F3D2822BAF0-515E
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487
Component: E Lenkrad Elektronik D03
VCID: 69D97657132C7C0A7E-4B82
Address 17: Instruments Labels: 4D0-919-033-MYX.lbl
Part No: 4D0 919 931 MX
Component: KOMBI+WEGFAHRS.VDO D42
Coding: 02283
Shop #: WSC 00753
VCID: 0D1162C74704C02AB2-5142
1 Fault Found:
00668 - Supply Voltage Terminal 30
53-10 - Supply Voltage Too Low - Intermittent
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump D11
Coding: 15118
Shop #: WSC 02314
VCID: 408F8BF340D65D4289-4EEC
4 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00991 - Interior Lights
28-00 - Short to Plus
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 37: Navigation Labels: 4B0-919-887-BNS3.lbl
Part No: 4B0 919 887 B
Component: Navigation BNO 0001
VCID: 326BD13BFE7AFFD20F-4AEC
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No: 4D0 951 177 B
Component: Innenraumueberw. D05
Coding: 00001
Shop #: WSC 00000
VCID: 285F3353C8A68502A1-5210
1 Fault Found:
01462 - Anti-theft alarm ultra sonic Sensor (G209)
Address 55: Headlight Range Labels: 4B0-907-357-DYN.lbl
Part No: 4B0 907 357 C
Component: dynamische LWR D02
Coding: 00001
Shop #: WSC 131071
VCID: 285F3353C8A68502A1-4B6A
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4D0 035 195 A
Component: Radio D00
Coding: 00117
Shop #: WSC 02314
VCID: 204F2B73A0967D42E9-4B1E
Address 76: Park Assist Labels: 4D0-919-283.lbl
Part No: 4D0 919 283
Component: Parkingsystem A8 RDW D06
Coding: 01108
Shop #: WSC 00000
VCID: 68DF73530826450261-517C
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4D0 927 156 CP
Component: AG5 01L 4.2l5V USA 1414
Coding: 00002
Shop #: WSC 00000
VCID: 79F92617638CCC8A8E-5142
End-------------------------(Elapsed Time: 04:25)--------------------------
All-Audi-Home
Roland
2011 A8L 4.2
2006 A6 3.2 Avant
2000 A8L 4.2
Ross-Tech: Home
1 Fault Found:
1 Fault Found:
10:56:23 Group 091
720 /min RPM
18.8 % Load
Cam Ctrl. OFF
10:56:23 Group 092
720 /min RPM
18.8 % Load
Cam Ctrl. OFF
10:56:23 Group 093
720 /min RPM
18.8 % Load
02
Coding: 06753
Shop #: WSC 00000
1 Fault Found:
Coding: 08397
Shop #: WSC 02314
Coding: 00180
Shop #: WSC 08376
Coding: 00427
Shop #: WSC 02324
Coding: 02283
Shop #: WSC 00753
1 Fault Found:
Coding: 15118
Shop #: WSC 02314
4 Faults Found:
35-00 - -
35-00 - -
00956 - Key 2
1 Fault Found:
00-00 - -
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
Coding: 00001
Shop #: WSC 131071
Coding: 00117
Shop #: WSC 02314
Coding: 01108
Shop #: WSC 00000
Coding: 00002
Shop #: WSC 00000
you cams are way out of sync... -22 and +9 are 31 CF's off, spec is plus or minus 8 CF's as I recall... Had similar issue on the S8 after I bought it.
quattroworld.com Forums: cam timing fixed, had to degree the cam today.. it was showing -19 in block 93 on bank1
