can I roll a used odometer FORWARD? (importing a Canadian A8)
#11
Take a look at this on Ebay, I have never used them but I have seen other some youtube videos changing the mileage. BUYER BEWARE.
Odometer Correction: eBay Motors | eBay
Good Luck, Bob
Good Luck, Bob
#12
I thought cars over 10 years old were exempt from odometer disclosure. i wouldnt even worry about it, just go in and title the car. They probably wont even ask mileage. if they do just say whats on the odometer. They have no way to track it, and it wont matter if you sell the car anyway.
New Jersey Odometer Fraud FAQs
WHEN ARE NEW JERSEY CARS EXEMPT FROM THE FEDERAL ODOMETER LAW?
Vehicles with a gross weight of over 16,000 pounds or that or 10 years or older are exempt from the requirements of the Motor Vehicle Cost Information Act.
Certain requirements of the Motor Vehicle Cost Information Act (those of subsections (b) and (c)(1)) do not apply if the State where the transfer of the vehicle occurs has in effect alternate motor vehicle mileage disclosure requirements approved by the Secretary of Transportation.
#13
But I've already taken a different tack, though. See next reply.
#14
swapped over the mph faceplate instead
Thanks, all. I believe I have sidestepped the need to roll the used odometer forward by re-installing the original cluster (with its correct odometer) with only the mph speedo (and fuel gage) faceplate (they're both on the same piece of plastic), swapped onto the original cluster, from the used one. NJ is OK with the odometer reading in km, but I may try to change it to miles anyway using VAG-COM, as I've been advised can be done. I'll be making a new post about my learnings from this project. I think I destroyed the speedo and fuel gage on the used US cluster by prying the pointer needles off (to get to the faceplate). The needles were attached so tightly that they pulled the shafts (with coils attached) out of the instruments with them. The needles are built so that there's seemingly no way to hold the shafts in the instruments when pulling off the needles, at least not without some careful Dremel tool work. Don't know if the coils and shafts can be placed back in. But I don't need them since all I used from the used US cluster is the mph/fuel gage faceplate.
There are several places (eBay) that advertise they can roll the odometer to whatever you need. $80 - $120. But instead, swapping over the faceplate was free.
SirCoryM
11-26-2003 06:29 AM
Lexx
10
07-09-2001 07:37 AM
