coolant leak by transmission
Hey guys so I've been trying to figure out where my coolant has been going. Well I put the car on a lift and let it run for about 30 mins. Turn off and get under it I see no trials of liquid or anything other than this bolt that has coolant dripping off of it. It's on the passenger side by the catalytic converter and a transmission mount. I don't see any hoses or anything. But I wipe off the drips and here they come again I don't get it please help
Have a look at the coolant bleed valves - numbers 2 and 3 in the pic supplied by Sam above.
They are small plastic pipes (with metal reinforcement tubes) going through a grommet on the firewall, with the coolant bleed screws on top.
I had a leak nearly the same as yours, was very diffucult to find as it would only leak reasonably slowly when the system was hot and pressurised. Turns out the plastic pipes had cracked along the moulding seam top and bottom and would weep under pressure. The coolant ran down the back of the hoses on the engine side and drip on the exhaust manifold - often left no evidence on the floor. Sometimes dripped off the exhaust just by the left hand Catalyst.
Tightening the clamps made it worse (had screw clamps/jubilee clips on it already).
Replaced the pipes with new items (bit pricey, but not too bad), coolant loss solved.
Audifastdaddy
13
06-05-2023 01:55 PM
carl viking
31
07-30-2022 09:13 AM
ECS Tuning-Audi
09-03-2015 12:45 PM
