cooling problems
#11
Bad coolant temp sensor?
#12
gauge is reading it and cooling fluid is hotter then ever... but ... today noticed interesting thing.
when I set heater to Hi it stays around 90 (90-91), but when I set around 24 degrees celsius than it goes up to 110 degrees... so when I open heater flaps for fluid to go freely it's ok ... why? air?
#13
110 is high. mine makes me believe 90 is the normal temp (can't really get this high at the moment, but when it was warmer the gauge would stay at a little below 90 all the time). btw, today I found that intermittent fan of WOT helps raise the temp to 90.
#14
seems normal: the heater uses engine heat and cools the engine as it works
#15
You can let the engine warm up; then, HOVER your hand over different areas of the radiator (after shutting down the engine and possibly removing the fans for easier access). The coolant reservoir can be a reference. If everywhere is the same temperature, probably the radiator isn't clogged inside.
#16
everything is evenly hot, but still when I turn less than "hi" than it heats up ... WHY?
and now new problem - last time gas tank ended when it hit around 45% (35liters) now it was around 85%(65 liters)
I'm starting to hate germans and new audis ... piece of driving ****s
#17
I'm going to suggest three things,
The first is to follow Silver_d2's advice and replace the temp sensor. It's inexpensive and this will rule out a gauge problem.
The second is that your original post stated you installed a second hand radiator.
**** it off and buy a new one - $400 isn't that expensive...
The third is that having had the heads off, is your car losing any coolant when it's doing all this hot running? As it may have a blown head gasket - especially as you say the mechanic was a scheister... You can test for this with a probe up the exhaust (at a garage), and a coolant testing kit (which you can pick up from auto shops).
As for your fuel problem, if it's running out of fuel at just under a 1/2 tank, this smacks of an incorrectly installed or sealed fuel pump assembly. Have you had the fuel pump out recently?
They are notoriously hard to mount correctly until you have some experience!
#18
I tried different temp sensor - no change
tried different old radiator - no luck
when heater is on less than hi it will heat up and will lose coolant through coolant reservoir tank cover
I know that fuel tank like my own pocket - when I bought it - it had 2.8 fuel pump with messed up piping, I bought right pump, set pipse right, bought new gaskets for pump housing ... and THIS happend after it ended near 45% of tank, but now it dies at 80% ...
and I followed every step in original schematics of gas tank
markN1689
Audi A3 / S3 / RS 3 MKII
189
02-19-2022 12:28 PM
abpuma
09-17-2015 11:39 AM
raiderrider
12
09-08-2015 05:46 AM
