Cylinder 4 Misfire after throttle Body Gasket replacement
Had left bank running lean error as well as various cylinder misfires errors. Root cause was a bad throttel body Gasket that is summed up quite will in the following video
Now the car is buttoned up keep getting a cylinder #4 misfire. Car has been stuck in the Garage, so no chance to run it hard in case of a fouled plug. Car has 77k Miles (2002) on original plugs. thought that it may be only a fouled plug? Will pull the plug and see how that goes first
What are good replacement plugs, am I cheap for not buying the $10 each expensive ones?
Thanks
Paul
Thanks
Paul
Avantgarde
09-30-2002 06:17 AM
