D2 S8 - Hit Rev Limiter on 3rd now ABS CEL are on
My car 2001 S8
I was doing some spirited driving and I hit the 3rd gear rev limiter and my CEL and ABS lights came on. I know my car is a 2001 but I'd like to drive a little hard from time to time and not have to treat it like a baby at all times like I usually do and as soon as I have a little fun it acts up. These cars a way to sensitive. Just venting.
If I decide to this again in the near future after resetting the CEL and ABS should I just turn off the ESP to avoid this happening or is this car just a little baby no matter what?
Anybody local to Granada Hills CA that would volunteer to reset this on a Sunday? My indie is closed today. I'll pay you, thanks.
My car 2001 S8
Raz
My car 2001 S8
I would try it a few redline runs with ESP turned off.
Did the CEL flash any at all at redline or just come on solid only? Flashing CEL is misfire (injector, coil, plug, timing, etc...).
Did the ESP icon flash at the time at all?
The ESP not only works with the ABS (to brake a single wheel to stop spin or side skid), it also controls the electronic throttle (cuts or eases off on throttle if wheel spin isn't stopped by braking the spinning wheel). In the S8 (unlike A8) the rev-limiter closes the throttle valve at redline (7200)....A8 cuts the injectors at it's redline (6600). I wonder if there could have been a momentary miscommunication between the ECM and ABS module, when the throttle valve closed at redline(?).
Codes read and further attempts at redline should tell it all.
If your indy doesn't have Vagcom, a simple code reader is not likely to tell you anything about the ABS module...parts store code readers mainly read ECM codes (misfires, etc) ...things that lead to emissions problems only.
PS: I'm a little over 2200 miles away, so I can't read your codes ...sorry
We would be curious to see what codes are read before they are erased.
Car was running rich turns out I needed a new MAF but after the install the car was fine until I did the same (WOT) and it did it again. Now after a 2nd opinion it seems the car has an issue with running rich with 1gm of air being read. The MAF is not getting a solid signal and this indie wants 6hrs labor to diagnose the problem before any repair is done. Says he has to check all wiring to the ECU to eliminate a guessing game. Says worst case I need to repair the intake manifold or at least clean it if their is a block somewhere but if not it's my wiring. He is certain my ABS is fine and is not the issue. Says the MAF will trip up the ABS and cause bad tranny shifts as well. If there is an issue with the signal being read from the MAF why would it be the intake manifold? Going to get a 3rd opinion. Car runs ok but tranny shifts could be better.
Anyone local to me here in the Los Angels area who would like to help me out. I started with Eurosport in Burbank then Wicked Motorsports in Van Nuys. Wicked seemed to know their stuff but I would like a 3rd opinion. Vic at Eurowerks is always too busy. Thanks in advance.
Tgr_Clw
49
01-18-2007 07:40 PM
BarryT
01-30-2004 02:48 PM
