How to Bleed Air from Heater Core - AudiWorld Forums
Old 03-11-2014, 02:53 PM   #1
Default How to Bleed Air from Heater Core
I just replaced the water pump on my 99 A8. Before the pump went out, the heating system worked fine inside the car and the temperature of the air couming out of the vents was perfect to whatever I had it set to. After filling the coolant, I started the car and attempted to bleed the air out of the system. I've done this a couple of times but still no warm air out of the vents. I have to assume I don't have the correct procedure down for bleeding the air. Can anyone provide me with instructions on how to do this? At first, it seemed simple enough, but after striking out twice, I'm puzzled as to what I'm missing. Thanks in advance!
ggjoy is offline   Reply With Quote
Old 03-12-2014, 07:01 PM   #2
I'm not sure about the PFL but the FL cars have two bleeder valves on the lines going through the firewall.
yrk2.7t@curbside is offline   Reply With Quote
Old 03-21-2014, 06:26 AM   #3
silverd2's Avatar
Quote:
You've probably already worked this out by now, but I only use the bleeder screws (or hose holes on other cars) as a starting point...fill to overflow, tighten down, then:
I go the old fashioned route (still recommended by Bentley) of starting the car with heater set to HI and running the car (sitting still) at 2000-2500 rpms for 5 minutes plus, reving to over 4000 rpms several times during this. During this time, I'll hear a quiet "pop", fluid flow, then a giant blast of heat. I top off the reservoir to "max"...then maybe a couple days later, top it again if needed.
After this, I have never had lingering air in the system with any car, including my D2.
Job done.
silverd2 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
The Daily Build..My S6, the story and the questions vwleadfoot Audi Original "S" Cars 4 12-24-2015 07:07 AM
Help with a 2004 Audi A8 4.2L Issue jeffkruse A8 / S8 (D3 Platform) Discussion 4 10-02-2015 10:19 PM
Can 00604 - Potentiometer Positioning Motor for Air Flow Flap cause no heat? ajg617 A6 / S6 (C5 Platform) Discussion 0 09-06-2015 08:23 AM
Frustrated 2004 Audi A8L 4.2L jeffkruse A8 / S8 (D3 Platform) Discussion 5 09-04-2015 12:59 PM
:: ECS Tuning :: B6/B7 S4 ECS Assembled Heater Core Refresh Kit ECS Tuning-Audi S4 (B6 & B7 Platforms) Discussion 0 09-03-2015 01:45 PM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
