Sponsored by:
Sponsored by:
Closing sunroof on '01 A8Lne
Old 08-23-2013, 08:15 AM
mdr1220's Avatar
Default Closing sunroof on '01 A8Lne
Do anyone know the location of the access point to close the sunroof by hand? My sunroof is stuck and I close it until I can get it fixed. Thanks
Old 08-23-2013, 09:51 AM
silverd2's Avatar
Here ya go >>>
Old 08-23-2013, 01:23 PM
silverd2's Avatar
A note:
The 2nd step SHOULD read to "carefully pry the LIGHT HOUSING downward"...not the LENS, which was already removed in step #1.
^^ Audi typo from my owner's manual ^^
Old 08-23-2013, 05:19 PM
mdr1220's Avatar
Thank you.
mdr1220's Avatar
LOL
Old 08-24-2013, 06:09 AM
twentysevenlitres's Avatar
Originally Posted by silverd2
A note:
Sam, in that case shouldn't the second paragraph of that second step read "keep pressing up"?
Old 08-24-2013, 06:40 AM
silverd2's Avatar
Yes...I saw that, too. I don't think anyone actually proof reads these owner manuals before they go out...they're full of confusing language like that.
Old 08-24-2013, 07:00 AM
mdr1220's Avatar
The mechanic I got it from said that it did not have a manual close on it. I looked at him like he was an idiot,I knew better. So I did a little looking around and found this forum and it took me less than 10 mins to close. Thanks again.
Old 04-01-2014, 06:14 AM
JAA 4.2's Avatar
Hopefully this will be helpful to someone as I didn't find this information yesterday...
My sunroof somehow lost the home position. Closed was half way open and open it was definitely bumping up against the rear stops. Winding it manually closed worked, but it still didn't open and close correctly. What I learned was when you install the tool, if you push up about 1/4" it disconnects the motor from the cables. This lets you move the sunroof relative to where the motor thinks it is. So, in my half closed position I pushed up on socket head that winds the cables and moved the sunroof fully forward. It all works correctly again. No idea why it got screwed up in the first place.
Old 04-11-2014, 05:57 PM
audijim113's Avatar
Wow. It pays to check back here once in a while. My sunroof has been stuck at a point where it won't close tight since last summer. It only tries to move in either direction and makes a short "err" sound.
Because it would leak, I pushed a rubber gasket thing in to stop it water dripping out of the light in a heavy rain or car wash.
I never read the part about pushing up the hex key. This weekend I was planning to put a careful bead of silicone all around and never try to open it again.
Tomorrow I will try pushing the hex key up and see what happens.
Tman007
A7
10
10-01-2015 07:25 PM
iamdrewseph
10-01-2015 11:33 AM
jetfire593
A7
09-30-2015 07:27 PM
HZ60
Q5/SQ5 MKI (8R) Discussion
09-30-2015 05:48 AM
Bruce B
09-25-2015 12:11 AM
Quick Reply: Closing sunroof on '01 A8Lne
