Leak from rear window. - AudiWorld Forums
Old 02-04-2014, 01:55 PM   #1
Default Leak from rear window.
I have a leak from the rear of the roof lining. I puled it down and noticed there is water coming through the top of the rear window seem. Anyone have seen this before?
S2600 is offline   Reply With Quote
Old 02-04-2014, 02:10 PM   #2
twentysevenlitres's Avatar
Just want to make sure it's not the sunroof drains blocked.
Having gone as far as you have, I'm sure you've ruled that out (assuming you have a sunroof).
Otherwise, you rarely hear of the rear windscreen seal going on any car. Best bet is a dealership or windscreen specialist to have it resealed. You will want to know how it's bonded in the first place though in order to seal it properly, so I would err with caution and go with the dealership.
I would check for corrosion too. Just because its Aluminium (spelling is correct ), doesn't mean it can't corrode.
twentysevenlitres is offline   Reply With Quote
Old 02-09-2014, 12:27 PM   #3
Had a look at it today. Defensively a leak in the rear window.
Thread Thread Starter Forum Replies Last Post
Rear camshaft adjuster valve leaking (category #3) underextended Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-12-2015 12:37 PM
95 a6 fwd 2.8. rec'd services @ 100k ? jonathanfilippi A6 / S6 (C5 Platform) Discussion 2 09-11-2015 08:52 PM
S8 Brembo crossover pipe leak Optimusglen A8 / S8 (D2 Platform) Discussion 0 09-08-2015 07:57 AM
Just checking to make sure I'm seeing what I think I am. bilbo6209 A6 / S6 (C5 Platform) Discussion 10 09-04-2015 05:07 PM
:: ECS Tuning :: NEW!! B8 A5 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-01-2015 09:27 AM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
