Low Windshield Washer fluid symbol in dash malfunction
Anyone dealing with this? The resevoir is full, yet the animated windshield washer fluid low sumbol still dances in the dash display instead of the radio info.
The archives mentioned VAG-Com which I did and which did nothing. I'm prety sure it's the sensor... maybe it's stuck? Is there a way to access this unit?
Thanks, Ed
Thanks, Ed
I'm having the same issue, only have to remove the drivers side fender liner. .. but
Must have a resistance value as nasioc troubleshooting didn't work. I guess I need a new sensor. .
Must have a resistance value as basic troubleshooting didn't work. I guess I need a new sensor. .
Also, since it wasn't mentioned, the level sensor is incorporated into the pump. The pump itself doesn't cost a lot from places like FCPeuro, otherwise you can snip the sensor signal wire (you'll have to do some searching for which one, there are 3 there) to be rid of the warning. Word of caution, if you snip the sensor wire, you'll no longer know when your fluid is low.
BoxcuTTer
12-27-2017 07:53 AM
engleg
A6 (C7 Platform) Discussion
08-20-2016 10:22 PM
VenTTed
09-24-2002 06:24 AM
