Rear wheel/locking judder on a8 quattro
can anybody enlighten me as to wat is causing this? oil level for rear diff is fine, mounting is ok too!
It only happen when I do a full lock and take off, at speed it is ok, only happens when taking off or at slow speeds! My one is a 95 4.2 4 speed auto UK spec. SOmebody told me the clutches in the diff are locking up against each other?? make sense to anyone?? tyres seem ok aswell
Do you happen to have the ability to manually lock the rear differential?
In my 95 Audi A6 i had a button that allowed for manual lock up of the rear diff.. It created the same exact symptoms you mentioned. If you do then your switch might be stuck.
Re: That's the torsen differential, at low speeds and full lock steering the wheels skip a little
ok, it never did that before, so what do I need to replace?? the rear diff??
Comeon guys! someone give me an idea where this torsen diff is or is it the rear one??
Re: The A8 has no torsen differential!
the rear torsen was replaced after the V8 in 1994 with the introduction of the A8 by an EDL which I have no idea where is or how it works??
can someone explain??
coupe d'mike
09-11-2006 08:32 AM
quattro20v
Audi Original "S" Cars
03-31-2006 07:07 AM
