Serpentine belt replacement met with difficulty - AudiWorld Forums
Old 01-09-2014, 09:07 AM   #1
Default Serpentine belt replacement met with difficulty
Hi,
So my serpentine belt was last changed at 53k km in 2006. Now it has 103k and is pushing 8 years. I've been planning to change it (have the belt in the trunk for some time already). Today I got the tool to remove the viscous fan. Here's the problem:
The fan is out of the way, but the tensioner bolt just won't budge. I tried the belt-pulling method mentioned on Audipages, but I think that only stretches the belt (and I don't think it's a good idea anyway).
Is there another way to remove the belt, or should I go to the dealer and let them do the job? I'll go to the dealer tomorrow to buy an oil filter and wiper blades. I'll at least ask them how much they'd charge for it. Should I spray WD40?
dreamhope is offline   Reply With Quote
Old 01-09-2014, 09:38 AM   #2
silverd2's Avatar
If the tensioner was working correctly, pulling down the belt would easily move the tensioner roller through it's range.
PFL has a very different tensioner than FL model...PFL comes apart in components...FL is one assembly.
It might just need a clean and lube...pretty simple assembly that works or doesn't.
And this is a message to anyone posting questions here:
STATE THE YEAR, MODEL & COUNTRY OF YOUR CAR or better yet, ADD IT TO YOUR SIGNATURE.
silverd2 is offline   Reply With Quote
Old 01-09-2014, 10:03 AM   #3
I also think the tensioner isn't working properly, or maybe my ratchet is too short. I have only 13mm deep socket for 1/4" drive. I forgot that I also have an adapter for 1/2" breaker bar. I'll try that tomorrow.
Also, even if pulling the belt had moved the tensioner with the front end and the water hoses on I couldn't see clearly. All I saw is that if I pull from underneath the belt on the harmonic balancer moves a little bit (supposedly from stretching). With the front end on, I don't think I could find the slot to insert an Allen wrench.
Old 01-17-2014, 09:49 AM   #4
Finally did it this afternoon with my newly-acquired 30" breaker bar.
the tensioner is not working properly, because when de-tensioned it stays at that position. After replacing the belt, I lubed it a little more and turned it back to the working position. Belt tension is good. Probably some rust.
Here's the old belt
Here's the new
also changed motor oil with Liqui Moly Synthoil High Tech 5w40. dealer filter.
Old 01-17-2014, 10:53 AM   #5
silverd2's Avatar
In my experience, normal (Continental) serp belts look like that already at only 10K miles...no loss of strength, but cracked ribs.
I now only use Dayco poly-rib belts...perfect after 30K miles on my D2.
Old 01-17-2014, 03:40 PM   #6
S8ilver's Avatar
Which part number for the Dayco? I've decided mine is probably due for a change as well.
This?:
Amazon.com: Dayco 5061055 Poly Cog K: Automotive Amazon.com: Dayco 5061055 Poly Cog K: Automotive
Specs: Product Dimensions 22.7 x 4 x 0.8 inches
However, I'm always hesitant to trust Amazon's fitment guide.
On Partsgeek I found 7494-07008871 as the part number, but that's only specific to their website.
S8ilver is offline   Reply With Quote
Old 01-17-2014, 04:32 PM   #7
silverd2's Avatar
Quote:
This?:
I bought mine at PartsGeek....and recently got one for my wife's AR through the local AutoZone for a similar price.
Thread Thread Starter Forum Replies Last Post
Mk1 tt overheating at idle Boosted01tt 1.8T Discussion 5 01-03-2017 06:55 PM
Introduction and pics of my new love LaserSVT A6 / S6 (C5 Platform) Discussion 64 01-19-2016 05:26 PM
correct Crankshaft seal size lotuseleven 12v V6 Discussion 6 10-07-2015 04:27 PM
95 Cabriolet Air Conditioning Clutch Removal. stormchaser1967 Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 1 09-02-2015 01:47 PM
Audi C4 2.6 Could not start aron56 Audi 100 / A6 (C4 Platform) 0 09-01-2015 01:39 AM
Tags
audi, b5, belt, belts, d2, passat, replacing, serpentine, v6
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
