Slipping Clutch?
#11
What is temp outside when this happens. The whining sound you hear? Its not steering related. The reason I ask my steering pump makes a whining sounds then the temps are below 10 f its fine above that.
Trans could be a little low on fluid too.
#12
It has been super cold out here in NY. But it def sounds like its coming from the trans.
I hear that whine when i turn my wheel alllllll the way to the sides. Its not that same whine
#13
How many quarts of fluid did you put in? Should have been seven or eight quarts. Depends on how long you let it drain.
Does the trans still whine when it is warmed up?
Sounds like you are sucking air by something.
Low oil level, filter not sealing on valve body, and suction port to trans oil pump. to name a few
New oil is thicker so maybe in this colder weather it is drawing air thru a some what weaker area. which will foam the oil and can make the trans shift funny. not having a dip stick to check the oil for a foaming condition other than removing the fill plug and checking there.
I live in Vermont so yes I understand it has been cold here to -10 to +10 here today.
I hope this might help out or a direction to go.
#14
As long as you didn't take a long time pumping fluid back in it should be at the correct level.
The flywheel is bolted to the torque converter but has no contact w/ the trans fluid, so there won't be any coating on it. If trans fluid could touch the flywheel you'd qucikly burn the transmission up because it would POUR out the two holes on the bottom of the bell housing that are open to air.
#15
Yes but not anywhere near as much as when it is first started after sitting for a bit
I would love to figure this problem out as oppose to getting rid of the car.
#16
trans level
Okay I think when you finish topping the fluid off while the trans is still cold. You run the trans thru all the gear ranges Then you run the car at a idle and this is what Audi manual said:
If the ATF level is correct, a small amount of fluid will come out at the ATF inspection plug when the ATF temperature is between 30° and 45° C → Note. (the fluid level will rise slightly as the temperature increases).
You may have over fill it. if you didn't let the trans get to proper temp before installing the fill plug. Over filling could cause foaming of the oil too if the oil level gets high enough.
also if the trans temp was to high when adjusting the level could cause oil level to be lower when cold.
Also the car must be level. while checking the fluid level.
To check for fluid foaming open the fill plug see if there is a lot of small bubbles in the oil.
Here is some more info in Audi repair manual about oil level
Note:
The ATF level will vary according to the temperature of the ATF.
Checking the ATF level when the temperature is too low will lead to overfilling.
Checking the ATF level when the temperature is too high will lead to under-filling.
Overfilling or under-filling the ATF impairs the function of the transmission.
The ATF temperature is read from -VAS5051- or -VAG1551-.
Hopefully this helps out. The above items are possible to cause issues you are having. not sure if they are only problem.
Note:
ECS Tuning-Audi
S4 (B8 Platform) Discussion
07-26-2018 02:02 PM
ECS Tuning-Audi
02-04-2016 08:36 AM
Audi A6 2003 allroad 2.7t for sale in AZ
blackjulia
09-27-2015 09:37 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-24-2015 12:06 PM
