Disappearing Trip Computer
Hey guys,
I'm finally experiencing a problem in my 2001 D2 S8 that has not yet been described here (I think). Up until now, this forum has been extremely helpful with DIY fixes to minor (and major!) problems.
Well, here's a new one I haven't found any information on. My battery recently got very low after the car sat for a few days, and the car would not turn over. Instead, the area where the trip computer is rapidly flashed, along with ignition clicks. After getting a jump, the car started back up and ran perfectly well, but with one exception -- the area where the temperature and 'miles to empty' previously was had disappeared, replaced by a black void. The P N D 4 3 2 is still on the bottom of the screen, and the warning lights are still visible at the top. When I open a door, or before I put the car in gear, messages are visible across the whole LCD, so it's not the panel. What could be the problem, and how would I go about remedying it? I surmised I could pull the positive off the battery for a few minutes to fix it, but wondered if there was another way (that wouldn't reset everything). Thanks in advance!
The middle part of the display can be toggled on and off by design. The button that toggles it is on the bottom of the wiper control stalk (towards the end). Just press that button and the display will light up again. Press again and it will go off.
I remember having that "oh no!!" moment before I learned about this.
Yeah, what he said!
Its in the owners manual if you're not sure which button.
The problem I have with the DIS is the auto brightness. The sensor sits between the Tacho and warning light grid right down the bottom of the dash cluster. I have tinted windows and my garage doesn't get much sunlight during winter, so I often drive off with a virtually unusable display.
If I want to use tip, I can't see which gear I'm in!
Very frustrating...
I want to see if the base level backlight can be adjusted via VCDS and bost it up a bit.
Very frustrating...
Thanks guys, for the info. I'm guessing the button you are referring to is the 'Reset' button on the right hand stalk (I bought the car without an owner's manual, unfortunately). I tried holding this down, but I'll try giving it a quick press to see what happens.
Well, this issue has been solved. You guys were right, a quick press of the button took care of the problem. However now, I'm being presented with more electronic gremlins. The cabin light (main) is staying on all the time, even when the switch is in 'doors open' mode (I had to turn it completely off). Even more troubling, the hazard lights will spontanously come on while I'm driving the car, and I am unable to turn them back off by pressing the button until I kill the engine. Any ideas?
Yeah, what he said!
Very frustrating...
Very frustrating...
Very frustrating...
Very frustrating...
Worth checkin
