Sponsored by:
Sponsored by:
04 Audi A8 car setup function doesn't work
Old 09-28-2016, 06:36 PM
Drizz215's Avatar
Default 04 Audi A8 car setup function doesn't work
Hi new to the forum . does anyone know why my car setup function says no further information available ? anything helps , I'm truly lost here !
Old 09-29-2016, 04:49 AM
richard-tx's Avatar
Why do you have your climate control set to high, manual blower speed, a manual vent selection? The On-Off button is worn too.
I think the answer to that may be related car setup issue.
Old 09-29-2016, 05:00 AM
Drizz215's Avatar
this is my first Audi in life Period, but i don't think my air conditioning inside my car would have anything to do with me not being able to adjust my ride height ! and other functions in car setup!
Old 09-29-2016, 06:11 AM
AudiWorld Wiseguy
dvs_dave's Avatar
Have you tried resetting the MMI? Google the button press sequence.
Old 09-29-2016, 07:10 AM
Drizz215's Avatar
yes I have reset the mmi, once it booted back up , it was saying the same thing still.
Old 09-29-2016, 07:18 AM
Giovanni Giovino 6.0+6.0TT's Avatar
Richard,
Please explain how.
Old 09-29-2016, 07:25 AM
the_duke's Avatar
Welcome! Glad to have you here.
I'm guessing that someone has been changing the coding with VCDS. Step 1 is gong to be a scan to see what errors you get. Also what can you tell us about your car. Any service history? Does it have any other problems? Sometimes seemingly unrelated issues can cause problems you wouldn't think of.
Old 09-29-2016, 07:31 AM
Hello Drizz,
I also notice that you are missing the "Date/Time" in the upper left corner, Please post pictures of what you see when just "Car" is pressed, then of "Car' + "Systems" (lower left button by big ****) .
Next would be to post a full scan with Ross-Tech cable and a screen shot of the "Installed List".
Old 09-29-2016, 11:27 AM
Drizz215's Avatar
Originally Posted by Giovanni Giovino 6.0+6.0TT
Hello Drizz,
As far as the pictures go I can do that , but the scan ? I don't know how to do that or know anyone in the Philadelphia area that does that, when I leave work I will for sure post a picture .
Old 09-29-2016, 07:31 PM
richard-tx's Avatar
Some of the functions of the HVAC system are cross linked to the MMI.
Now if your HVAC functions are hosed, that could adversely affect the MMI.
For example, who would have thought that a bad ground in the sunroof of an A4 would affect the tachometer in the cluster? It can.
Hi in this case usually means full heat. If you aren't getting run out with the heater, then the heater control valve isn't working right.
Another example is a break in the MOST (mutimedia) network. All manner of strange things happen if that occurs and the MMI can just shutdown.
A VCDS scan is what you need.
Quick Reply: 04 Audi A8 car setup function doesn't work
