06 A8 camera retrofit pursuit...
#131
Hello guys!
I had followed the steps of this retrofit and everything was going pretty much ok except the camera signal is crappy and I don't know why when I put on reverse this is what happens:
[youtube]phBvl6HcMBU[/youtube]
Next week I'll try with other camera and see whats going to happen.
The camera is CCD aftermarket 25$ piece of sh*t....Maybe this seems to be the problem or it's related to the type of signal camera works with , I really don't know?
I can not find OEM camera and handle.
What should I do?
Thanks!
What should I do?
Thanks!
#133
It's not the camera, it's your circuit
I used $20 camera and it's better than the original VW golf's.
Before blaming on something, make sure everything works. A simple test, hook up the camera to the home TV to see if it works. If it does, then hook it to the backup camera unit powered with 12v constantly on, not switching . It doesn't look like you have power to the camera or your retrofit was bad.
#134
Problem solved.....I bought a new camera without guidelines and NTSC signal (not PAL)
Everything is fine!
Thank you Louis! It was a great help to read your write up for this retrofit!
Wouldn't be bad using constant 12V on the camera? I hooked it up on the reverse light..
Everything is fine!
