Sponsored by:
Sponsored by:
MMI/radio help
Old 01-14-2020, 04:17 AM
Mx-3GSR's Avatar
Default MMI/radio help
So the MMI started acting up ( I suspect water in the left side trunk) the was a tiny bit of water on top on the Navi unit
what it does is start up and just "click" and shut down about ever 1 second sometime the radio will come on for a second other wise its just clicking
So I need a bit of help, in my car there is what I think is the reverse sensor module mounted to the Navi unit at the top and next to the wheel well the Amp then under the Navi unit is another "box" (not sure what that is)
What I need help with is diagnosing the problem.
I have removed all the boxes opened the and sprayed down with electrical contact cleaner. it didnt work
I ordered a fiber optic loop. when it comes Im going to hook it up in place of the Navi unit (Im hoping this will fix the problem, order a new Navi box and done)
am I correct or what should I expect?
Thanks
Old 01-14-2020, 06:53 AM
ltooz_a6_a8_q7's Avatar
Just wait for the loops and start plugging all suspected components
Old 01-14-2020, 07:25 AM
Mx-3GSR's Avatar
ok thanks
just so I have a better understanding does start in one place and need to continue a loop?
for example start with some "box" in the dash the go to 6 disk changer then to the AMI then to the Navi then to that other "box" below the Navi
But what I'm thinking now is it starts in the Trunk in that "box" and then goes to the front
Thanks
Old 01-14-2020, 07:40 AM
Hopefully you bought more than 1 LOL.
Old 01-14-2020, 07:52 AM
Mx-3GSR's Avatar
nope just one
Old 01-14-2020, 10:00 AM
cu52's Avatar
I have a Navigation module available if that turns out to be the issue.
Old 01-31-2020, 12:16 PM
Mx-3GSR's Avatar
So I got my loop today
i unpluged the 4E0 035 541 P
what I now think is the radio module
everything but AM/FM works
can I just buy and replace or it that module protected some way?
Old 01-31-2020, 02:34 PM
I doubt the radio is bad, check the wiring, fuses, power wiring.
Old 01-31-2020, 05:19 PM
Mx-3GSR's Avatar
It definitely had water in it at ome point
inside has some rust
Old 01-31-2020, 06:06 PM
Did you open it up? So voice control now is not working I assume. Did you check the fuse on the radio?
Quick Reply: MMI/radio help
