100k miles, need to change transmission oil??
#31
Sorry to hijack these thread but i have a question regarding oil change 2009 A8L 4.2 TDI (127 000km on the odometer and live in Norway)
Im planning on removing my DPF and remap it. The guys who are doing the tune said they didnt want to do it before the transmission oil and filter is replaced.
Since ive pasted 120 000km i think its a good anyways to replace filter and oil.
Due to the age of the car (2009), is it safe to say that it is the ZF LifeGuard 6 is the correct oil?
Havent found any evidence (bills or service manual) that indicates that it has gone through a oil change earlier.
Regards
Kenneth
Regards
Kenneth
#32
AudiWorld Wiseguy
Lots of info below but LF6 is good
ATF change isn't listed as an Audi service item, but is by ZF the transmission manufacturer.
In short, this topic has been done to death and an ATF and filter change at 80k miles is a good idea to maintain optimum transmission performance and longevity.
LF6 or an equivalent will work just as well.
See here for info on ATF as it applies to the D3:https://www.audiworld.com/forums/a8-...truth-2882676/
Here for firsthand experience of using an alternative to LF6:
https://www.audiworld.com/forums/a8-...ected-2883008/
And here for the official info from ZF: http://www.zf.com/global/media/en_us...s/TE-ML_11.pdf
#33
I have not killed mine yet
I do my own maintenance mostly. And go way overkill. Oil at 5K, air and cabin filter at 10K, flushed everything best I can.
My next tranny service will be open fill port and let 3 1/2 - 4 liters drain out. Then start car and shift forward to reverse and fill back up with LG 6. The filter and fluid was changed at 70k and 10 years. Thinking maybe 110k is when It will be good to drain and fill. This should cover it to 150k.
By then I may be tired of pulling air box for oil changes. Move on.
#35
Regards
Kenneth
Regards
Kenneth
#36
#37
Is there a DIY on this anywhere? I've never done the transmission fluid, but my car just hit 100K and I would like to change the trans fluid and filter myself. Just would like a clear guide before I tackle it. Thanks!
#39
i'm at 155k with original fluid...tranny does shift hard between 1-2.
We did own an 2000 2.8 A6 with 220k miles or more and never changed fluid and it shifted very smooth
#40
