Sponsored by:
Sponsored by:
How the HELL do you get the intake hose off the throttle body?
Old 05-16-2014, 08:00 AM
aTOMic's Avatar
Default HELP me get the intake hose off the throttle body?
Any tips appreciated. Preferably without removing manifold.
Thanks,
Tom
Last edited by aTOMic; 05-16-2014 at 11:12 AM. Reason: Thought the title a bit dramatic...
Old 05-16-2014, 08:21 AM
tjf
tjf's Avatar
There should be a band clamp around the connection point. It will then slide straight back. I know this because mine loosened up and it slid off, causing me all kinds of issues. It is not easy to see. You may have to remove the pvc valve and climb on top of the engine to get at it.
Old 05-16-2014, 09:46 AM
mishar's Avatar
Thanks,
Tom
Unscrew the filter top first. That will give you a bit more space and better angle. Even than it is art of engineering at its best.
Old 05-16-2014, 09:47 AM
aTOMic's Avatar
Thanks, Tom. and Misha
I got it, one piece at a time. Love the hose-to-nowhere (Resonator?). It was that big flat throttle control valve was the big impediment. PCV is smaller and down by the back I think.
Found the broken vacuum line to the driverside (new word I just made up) EGR(combi) valve; replaced it all w/ silicone tubing. we'll see if it holds up.
HAAPPY!
Tom
Last edited by aTOMic; 05-16-2014 at 10:55 AM. Reason: First, Forgot "EGR/combi valve", second edit: to fix "reason for editing"
Old 05-16-2014, 02:02 PM
tjf
tjf's Avatar
HAAPPY!
Tom
Big flat valve is the world's most expensive pvc. ...well maybe not the most, but the most expensive I ever heard of. $136 msrp... $91 through Carson. That was the first thing I replaced, before finding the loose band clamp. ...Glad you found the problem and it was a cheap fix!
Skribbs2000
10-27-2009 04:12 PM
dhamilton
12v V6 Discussion
12-02-2008 04:55 PM
groovetek
30v V6 Discussion
05-28-2007 09:11 AM
snowman '92 100
Audi 100 / A6 (C4 Platform)
07-21-2004 10:53 AM
wws03
03-18-2004 04:50 PM
Quick Reply: How the HELL do you get the intake hose off the throttle body?
