Sponsored by:
Sponsored by:
2 fixes I did, and saved $2000 for $7 fix !
Old 05-14-2014, 03:50 PM
allenst's Avatar
Default 2 fixes I did, and saved $2000 for $7 fix !
vehicle: 2004 A8L with 150KKm.
1st issue: check engine light on. Stealership ays just keep driving otherwise we will have to trouble shoot at $125 and hour. We will start with replacing O2 sensors........ Radar goes up. Stealership, and you cant pull codes and identify ??? Went to a Volks aftermarket tuning speacialist....same BS. went to a tinker kind of Audi guy, same thing. They're all 'businessmen'. cost would have been in $800 - $1200 range.
bought a $40 check engine code reader.
lean codes p0171 and p0174 came up.
first and easiest and cheapest starting point = cleam maf sensore and clean air filter.
result = check engine light off now for 1200km's.
cost = $7 !
next issue I solved.
Truck lid motor not engaging and locking trunck.
All the 'repair people' or as I know them 'parts changers' suggested change motor and hinges and lube + labour = $700
solution and fix.
WD-40 on all hinges and lock.
followed by graphite lubricant after wipedown.
immediate result = trunk locks, trunk motor works fine.
Old 05-15-2014, 04:30 AM
Jehu8's Avatar
nice
Old 05-15-2014, 06:59 AM
mishar's Avatar
cost = $7 !
solution and fix.
$7 and a ton of luck. Usually it is not so simple. But that's why this forum is here.
Old 05-15-2014, 11:27 AM
bmwm750's Avatar
cost = $7 !
solution and fix.
That's called dumb luck
Old 05-16-2014, 02:14 PM
ltooz_a6_a8_q7's Avatar
Default With Audi A8 D3 - It doesn't have to be expensive to fix
We always tend to think of the worst when things failed and sometimes, they are just simple hick ups and need simple fixes.
Congrats,
Louis
dspur15
16
02-17-2019 05:15 AM
QPower95
04-22-2010 12:26 PM
FWD
02-04-2009 05:28 AM
dragaknee
04-29-2004 06:24 AM
maximumdownforce
03-31-2004 07:29 AM
Quick Reply: 2 fixes I did, and saved $2000 for $7 fix !
