2004 A8 INTAKE MANIFOLD PRESSURE SENSOR
#11
How about posting what the scan itself is? Sort of treasure hunt otherwise w/out sharing the underlying diagnostics.
The parts diagrams show that part in some, but it depends on motor on a worldwide basis. If it is somewhere on yours, the parts diagrams for motors where it appears have it back on a vacuum hose near the power brake unit. That would probably put it in the plenum area rather than under hood--or right against firewall if it is where the lines come through the firewall to connect to intake area.
#12
Well, first off you blurred the site info so we can not see where it is that you are confirming compatibility, I can assume that you are going by the EBay ad which states "Seller assumes all responsibility for this listing", and the seller appears to be wrong, I ran that part number that you listed and it is not compatible with a A8L 4.2 N/A gas engine, I do know that I have two of those on my Bentley, BUT it is twin turbo charged, AS MP asked, what are you scanning with, you must use Ross-Tech or VAS, NOT some generic scanner.
#13
AudiWorld Wiseguy
Misleading thread title due to Shonky generic code reader
He's actually looking for the brake booster pressure/vacuum sensor. That's what the part number ties back to: 036906051C
https://parts.audiusa.com/p/Brake-Fl...36906051C.html
You'll find it along one of the vacuum lines coming off the brake booster/servo. Seems the same part is also used as the boost pressure sensor on turbo motors also.
#14
He's actually looking for the brake booster pressure sensor. That's what the part number ties back to: 036906051C
Pressure sensor. PRESSURESENSOR for 2004 Audi A8 Quattro. #036906051C
#17
I can add that car has a bit of a stumble off the line and bit of a rough idle. Check engine light on. MAF just replaced (its code went away). New air / cabin filter and plugs ready for install.
#18
5. Remove the throttle body and MAP sensor from the intake manifold. If fouled with oil clean them. I cleaned the MAP sensor with carb cleaner and low pressure compressed air to dry. Be gentle.
#20
