2005.5 A8 4.2L - About to do Timing Belt
#11
No, the "bottom left" bolt. Buy the correct gaskets from a dealer. The "figure 8" as well as ones for the coolant pipes (five end seals). It's a good idea to have an assortment of metric nuts with different hex sizes and same thread size to help remove the dreaded exhaust manifold stud.
#12
For the timing service you also want the little tool to tension the cam belt and as Mister Bally said use a good puller when breaking the cam gears loose. I bought the tensioner tool and the correct cam puller when I did mine and I don't think they were very expensive.
For the oil pipe there is some good info in the link below. You definitely want the figure 8 gasket and all new seals for the alternator coolant pipes. Timing belt is easy. Oil cooler pipe is not.
https://www.audiworld.com/forums/a8-...-pipe-2901800/
#13
I'll be doing my TB sometime in 2017 (or maybe over the holidays) so want to know what *else* to plan for.
#14
I didn't change my coolant pipe when I did the timing service. I changed it when it broke. Personally I don't think it's that big of deal to put the car in service position. But you never know when/if the pipe will fail. I got lucky and it failed in my driveway at home. If it had failed on a long trip it would have cost some serious money and time to have it towed home.
#15
I just changed my oil cooler pipe this past weekend. What a miserable job for my son & I to do. Be prepared to fabricate a custom tool by cutting off part of an Allen Wrench and using a Box wrench to turn.
For the timing belt; be sure you have a gear puller that pulls straight, not on an angle. Hate to see how much a camshaft pulley would cost...
And yes, to some of the points here and elsewhere, I would only do the job with a gear puller that works for the job. I did one 30 years ago with the old rubber mallet and generic gear puller on one hand, and several times on various motors including on the 4.2 with the proper one. Night and day difference. Cam gears can also bend by the way w/ crap tool approach...BTDT. And since no one has mentioned it, I will label this area (and tool) as one with real personal safety issues. If that cam snaps back (and it will!) and your finger is anywhere near the teeth, it can quickly be a trip to the emergency room, and maybe more than just stitches. Net, working at the cam gear while under valve spring tension load has risks and I would not cheap on that tool.
#16
Thank you all for the replies. honestly this is the most help I've had on a forum haha.
so what I gather for replacing this oil cooler pipe is I'll need 4 o rings that come on it, the figure 8 o ring, o ring for alternator ports (how many?)
and does the oil cooler it self have a gasket to seal it to the block?
#18
#19
This link doesn't show the figure 8 seal.
Online Audi A8/S8 quattro spare parts catalogue, USA market, 2005 model year: engine group, oil pump, oil filter, oil filter bracket, oil dipstick, oil cooler subgroup, Audi VIN decoder, aftermarket, etka online
**Edit** The part# isn't pictured or numbered but it's there. 077198405
