Sponsored by:
Sponsored by:
2005 audi a8 d3 brakes
Old 02-07-2016, 10:48 PM
darkchildbati's Avatar
Default 2005 audi a8 d3 brakes
Hello all! good day! well i am going thru this issue, which is bothering me alot, i had ordered a set of brake pads for the front and the rear for my Audi A8 2005, just got them installed. everything was done correctly, using vcds/ross tech. now my instrument cluster shows this yellow circle with 3 thingys on each side of the circle, after doing some research i found out that the sensor cable might be loose, but i checked everything nothing seems to works, can someone please direct me to the right track, thank you all. have a great day
Old 02-07-2016, 11:43 PM
drago_o's Avatar
Did you code thickness of pads? Did handbrake test does good? Maybe forget to plug in in front pads?
Old 02-08-2016, 12:38 AM
Thickness was registered, front brakes sensors are plugged in, I don't know where the problem is
Old 02-08-2016, 02:35 AM
Jack88's Avatar
Is a VCDS scan showing any codes?
Old 02-08-2016, 08:45 AM
No codes what so ever
Old 02-08-2016, 09:02 AM
Mister Bally's Avatar
Are you using the genuine Ross-tech VCDS or a generic tool? Generic tools will not list many VW/Audi specific codes that are not part of SAE standard fault identifiers.
I apologize if you're using the real VW/Audi tool.
Old 02-08-2016, 09:05 AM
Yes it is an 100% original VCDS, got it done from my mechanic, he told me he hasn't seen anything like that before
Old 02-08-2016, 10:00 AM
Banned
JohnnyJ A6Q's Avatar
My buddy did a brake job on a 08 A8L, using his $20,000.00 Snap On system to open and close the calipers, but came to my house for the finishing touch, it took me a hour +/- to get it right, it just would not take, but after inputting the info many times, all was good.
IIRC I added or subtracted a MM or 2.....
Old 02-08-2016, 11:40 AM
Hi johnny J thanks for your reply, me and my mechanic tried multiple time inputting the thickness of the pads, it would only take 12mm, and all the sensor wires are connected, i ordered quality brake pads, so i have no clue what is going on
Old 02-08-2016, 12:42 PM
Banned
Did your guy follow these steps, and did he do the "Function Test" ?
Open Rear Parking Brake for Pad Change
Connect a battery charger.
Cycle the Parking Brake ON, then OFF first.
[Select]
[53 - Parking Brake]
[Basic Settings - 04]
Group 005
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
The brake pads are now opening.
[Done, Go Back]
[Close Controller, Go Back - 06]
Note: Check/Change Adaptation Channel 006 (Pad Thickness) after changing the pads.
Adaptation
Channel 006: Pad Thickness
Enter the measured thickness of the new pads (excl. back panel), round down to the next lowest integer.
Range: 3 - 14 mm .
Close Rear Parking Brake
[Select]
Group 006
[Go!]
[ON/OFF/Next]
The brake pads are now closing.
[Done, Go Back]
Function Test
[Select]
Group 010
[Go!]
[ON/OFF/Next]
The brake pads are now opening and closing 3 times.
Wait 30 seconds after the brakes stop making noise.
[Done, Go Back]
Longitudinal Acceleration Sensor (G251)
System voltage at least 12.0 V.
Car parked on a level surface.
Do NOT move/rock car while performing basic setting.
[Select]
Group 020
[Go!]
[ON/OFF/Next]
The status of the Longitudinal Acceleration Sensor (G251) is now being displayed.
[Done, Go Back]
Quick Reply: 2005 audi a8 d3 brakes
