2005 audi a8 d3 steering column
#11
AudiWorld Wiseguy
Unlikely both motors failed at once so fuse is your first check. Then, a common problem on the A6 which electronically is similar, is that it can forget it's motion adaption setting so just stops working. It basically needs to be reset and the adaptation done again and then it should start working again. Either way VCDS is essential for the fix. Check the A6 section for a how to.
#12
Mine was not moving a while back after doing some work.
Forgot what it was but something to do with coding.
Is the column adjust button active ?
Checked fuses ?
Checked fuses ?
#15
Thank you all for helping out, its always good to get advice from the pro's, i am going to get the scan and check all fuses and report back as soon as i do that. once again, thank you all.
#16
My steering wheel colom was not working to when I have problems with the left side of the Canbus in my A8L . After pulled the Canbus plugs above the fuseboxes and insert them a few times in and out it went working again.....and aswell other moduls on the leftside worked again......
AVANT S4 KING
Southeast Discussion
03-12-2006 03:49 AM
Picked up a 1985 Audi 5000s with 37k on it for 300 bucks... seems to run great. Needs a few parts(m)
EvanUrS4
08-13-2003 06:08 PM
Gunny to you maggot!
09-04-2001 03:12 PM
