2006 A8 4.2 intake manifold vacuum line
#11
I would really appreciate that, but certainly don't feel like you need to go out of your way. I am thinking yellow should route to charcoal canister, white is correct currently as a fuel supply line, so now I have to get the blue to return excess fuel to the tank. I suspect that the line to the charcoal canister is for some reason missing or misrouted. I feel bad being new to the forum and having you guys do all this work for me lol
It would appear that you car is different then mine, unless whenever whoever changed the engine they completely forgot to put back the blue hose. This just adds to the mystery. I think it might be in your best interest to find out what fuel injection system you have, and/or bring it to someone who has experience with these cars.
#12
Danm, I thought you meant the little, hard line at the left! The big line, I dunno!? Where does the other end go?
Haha good advice!
That reminds me, what is the engine code of your car?? It's stamped on the front top surface of the right head IIRC. Mine is BFM as are all 2004s in US but they could've replaced it with a newer one (although it appears you have the "old style" PCV/crankcase vent valve so = 2004=BFM); let us know which engine they put into your car please.
#14
Okay so from google searching, I think you may have cracked the case here on what prompted the problem. My car is a 2006 which from pictures online appears to not have a fuel supply return line? But this engine may be the 2004 style as you mentioned, which does have a return line. So I suppose I could try to find a 2006 style fuel rail, or I could try to figure out a place for excess fuel to return to the tank
#15
Apparently my fuel filter has a built in pressure regulator. I think I can probably block the return fuel line off and maybe I'll be good. I hate that this car has been messed with and isn't straight forward
#16
Never heard of that, but I don't know everything.
#17
My mistake; that's on my 1.8T. There are the smooth spots corresponding on the 4.2 but below is from Bentley. Just hope your engine matches the code from the vehicle data plate (located near the spare tire and in owner's manual; take a pic of it you may need it in the future). 2006s had either BFM or BGK engines.
That would suck.
That would suck.
#18
BGKs have no FPR.
#20
Ya that's a pretty sweet design. I capped the return line, haven't driven the car yet but hopefully it'll run fine like that. It seems that I am slowly working all the bugs out of the car. I wish there was one local I could look at for reference. Seems that the A8 is relatively rare
