4.2 liter 8 cylinder gushing oil out of drivers side of engine.
#22
#23
I called audiusaparts and they are looking into it as well, if I get any info I will post. It doesn't make sense that you would need to replace the head for a seal/plug. Could this be part of the cam plug /seals?
#25
I doubt it. The guy from the dealer sent me an explosion diagram of the head parts. I had to mark the part myself (its on the reverse side of the engine; drivers side head, rear):
#26
I need to look but is the passenger side cylinder head the exact opposite of the drivers side head? So this part should be on the front of passenger cylinder head. I am also going to send the image you posted to my neighbor who is an Audi mechanic at a local dealer and see if he can assist in identifying this part for us. Not sure if anyone else has experienced this issue on the forum. I am a newbie to the Audi world and in the learning curve. Anyone know of an Audi Machine shop in the US that have rebuilt these heads?
#27
The plug comes as part of #20 and #21 in 2005 Audi Audi A8/S8 quattro United States market: Engine Camshaft, valves 3.7/4.2ltr. 8-cylinder+ petrol eng.+ BFL,BFM
#28
Now it makes sense, those are the rocker shafts, and those rocker shafts are oil pressurized to lubricate the rockers, most likely the plug was pushed out over time by oil pressure, that is why you have oil gushing out, you would be better off checking the bore size and getting some brass freeze out plugs and try for a tight fit, or you can spend the $227 - $330 for the shaft only to find out the plug is pressed in I believe, also not to be Captain Obvious, replacing those rocker shafts is a head off job on the driver's side (USA).
Also I am not sure who's picture is posted with the shaft retaining bolt removed, if it is one of the members engine, put that bolt back before you do anything else, if not then you risk the shaft sliding out somewhat and then the last rocker may fall off......
#077109372D: Volkswagen. ROCKER SHAFT.
#29
#30
Extremely helpful, thank you. Im looking into plugging the hole with a neoprene expansion plug from the hardware store. There isn't much room to swing a mallet back there without taking the head off so a brass plug doesn't seem to be the best bet. Is it feasible to buy a rocker shaft from the dealer and knock the plug out of it and reinstall in the engine lol
428 FOH/185 PSI rated
Hand Tightening Aluminum Single Test Plugs With By-Pass - Petersen Products Company
https://www.grainger.com/product/5NR...=AZIDPBR_56173
25 FOH/10.838 PSI rated
https://www.grainger.com/product/SHA...xpansion-6VFR1
https://www.grainger.com/product/SHA...xpansion-6VFV3
