AAC retrofit and Instrument cluster swap
#22
If you haven't already visited this link may be of help.
http://audiforum.us/threads/a8-adapt...retrofit.7800/
Please keep us posted as this is something I am also interested in doing.
#23
#24
Tested my ACC radar today in my friend's factory ACC 4.0TDI 2005. The unit worked, and was detected and could be diagnosed with the VAS5054A tester.
Paid 120euros for the unit, NOT a bad deal
My friend's car had this pinout for the ACC radar behind the front bumper:
1. Brown (-)
2. Orange/violet (CAN-H to J533 Diag interface pin13)
4. Orange/gray (CAN-L to J533 Diag interface pin26)
6. Green/Gray (some useless K-line diag to under the left dash)
11. Red/Green (some useless diag to under the left dash)
12. Blue (+12v from fuse 17)
So it's just me who has wired the radar the wrong way, or then my gateway ending F hasn't got the same pinout as the H and A ending gateways. The F gateway IS a ACC gateway, as it gives a "acc missing" DTC all the time that my NON ACC "B" gateway didn't give.
Now to get an wide-instrument cluster, and rape the glovebox another time to rewire the J533.
1. Brown (-)
#25
ACC retrofit A8 4.2 TDI 2008
Hi, last week I tried to retrofit the ACC to my A8 4.2 TDI (*2008).
Mounted the radar & grille, swapped the ACC stick, cluster and Gateway.
Connected the following pins :
1. Brown (-12V)
2. Orange/violet (CAN-H pin 13 gateway)
4. Orange/gray (CAN-L pin 26 gateway)
12. Red Terminal 15 (+12V) ignition
I went to the AUDI workshop in order to remove the CP lock.
After that we did the necessary coding on Engine, Instrument cluster, MMI and Steering wheel.
CONTROLLER 01 Engine
CONTROLLER 07 Control head
CONTROLLER 13 Auto Dist Reg.
CONTROLLER 16 STEERING WHEEL
CONTROLLER 19 CAN GATEWAY
Then we went for a test drive.
The ACC was NOT functional, the following failure codes appeared:
Wednesday,30,December,2015,16:17:54:13314
VCDS Version: Release 908.0
Address 13: Auto Dist. Reg Labels: None
Control Module Part Number: 4E0 910 561 E HW: 4E0 907 561 E
Component and/or Version: ABSTANDSREGELUNGH01 X040
Software Coding: 0011168
Work Shop Code: WSC 65239 001 1048576
1 Fault Found:
01315 - Transmission Control Module
013 - Check DTC Memory - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10111101
Fault Priority: 5
Fault Frequency: 2
Reset counter: 154
Mileage: 210700 km
Time Indication: 0
Date: 2015.12.30
Time: 16:11:00
Freeze Frame:
Temperature: 18.0°C
Voltage: 13.70 V
Bin. Bits: 00000010
I tried to reset this fault. Without result!
There even were no faults in the Transmission Module.
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 S HW: 09E 927 156 B
Component: AG6 09E 4,2 TDI RdW 0010
Revision: --H01--- Serial number: 0116220
Coding: 0000001
Shop #: WSC 02313 785 00200
No fault code found.
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 A HW: 4L0 907 468 C
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1000D08225800E
Coding: F5F99FFF113E0E00
Shop #: WSC 99935 211 17899
ANY HINTS? Any input would be appreciated.
Here VCDS coding for all the components involved in retrofit:
CONTROLLER 01 Engine LOGIN II code 16167 to deactivate GRA and code 13647 to activate ACC.
CONTROLLER 07 HU must be adapted to support ACC with VCDS in adaptation CH01 added +00001
CONTROLLER 13 Autodistance Radar sensor controller has to be coded following this label:
My code is: 0011168
Position 1: Engine coding
1XXXX: 8-cylinder (4.2-litre petrol engine and 4.0-litre TDI engine and 4.2-litre TDI and 4.2-litre FSI)
2XXXX: 8-cylinder (3.7 litre petrol)
3XXXX: 6-cylinder MPI (3.0 litre with Multitronic gearbox "01J") and 6-cylinder TDI (3.0 litre with 6-speed gearbox "09L") and 6-cylinder FSI (3.2 litre with Multitronic gearbox "01J") and 6-cylinder FSI (2.8 litre AVS with Multitronic gearbox "01J")
4XXXX: 12-cylinder 6.0 litre petrol engine and 10-cylinder FSI 5.2 litre petrol engine
Position 2: Country coding 1
A 1 is always entered at this position
Position 3: Body coding
XX1XX: Standard body
XX2XX: Stretched body
Note on position 3:
This coding adapts the vehicle mass and wheelbase accordingly.
Position 4: Country coding 2
XXX1X: USA (mph)
XXX2X: Canada (km/h)
XXX3X: ----------------------------
XXX4X: Japan
XXX5X: RoW (mph) (RoW = Rest of the World)
XXX6X: RoW (km/h)
Position 5: Optional extras (added together)
XXXX1: Vehicle with trailer hitch and/or Rear Seat Entertainment system fitted- If one or both of the systems is/are fitted, the adaption value is always 1!!
XXXX4: Vehicle with one-touch memory
XXXX8: Without optional extras
If no optional extras are coded, the coding value 8 is entered
CONTROLLER 16 STEERING WHEEL has to be coded
0xxxx?x: Board Computer / Cruise Control System (CCS) / Adaptive Cruise Control (ACC)
0 = No Board Computer - No Cruise Control System (CCS) - No Adaptive Cruise Control (ACC)
1 = with Board Computer
2 = with Cruise Control System (CCS)
3 = with Adaptive Cruise Control (ACC)
4 = with Board Computer and Cruise Control System (CCS)
5 = with Board Computer and Adaptive Cruise Control (ACC)
CONTROLLER 19 CAN GATEWAY has to be coded activating the Distance Regulation using Long Coding or checking the new option in Gateway Installation List and saving it.
1. Brown (-12V)
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 154
Mileage: 210700 km
Time Indication: 0
Date: 2015.12.30
Time: 16:11:00
Freeze Frame:
Temperature: 18.0°C
Voltage: 13.70 V
Bin. Bits: 00000010
Coding: 0000001
My code is: 0011168
Note on position 3:
XXX1X: USA (mph)
XXX4X: Japan
XXX6X: RoW (km/h)
#26
Banned
Hello mmi.drachten,
I believe that you must change the cab-bus gateway to a "H", I have read that some have had the same gateway as you listed, and were able to check ACC box in the installation list along with coding same, but ended up with it not working until they replaced the gateway with the latest version "H" below are the versions and what they support, yours looks to only support "8T1" CCS for the A8, not "8T4" ACC, although it supports "8T4" ACC in the A6 and Q7, but not A8.
Your Gateway,
Stock Code 4L0907468C
(A6) Audi A6/Avant
4F0 910 468 A.
4F0.910.468.A.
4L0.910.468.
4L0.910.468.A.
606 -907-.
907 -209-.
PR-8T1+7Y2.
PR-8T4.
PR-8T4+7X7.
(7X0) Park distance control: Without park distance control.
(7X1) Park distance control: Park distance control.
(7X2) Park distance control: Park distance control, front and rear.
(7X4) Park distance control: Park distance control, front and rear.
(7X7) Park distance control: Park distance control rear with rear view camera.
(7X8) Park distance control: Park distance control, front and rear with rear view camera.
(7X9) Park distance control: Rear view camera.
(7Y1) Side assist/lane departure warning: Lane change assistant.
(7Y2) Side assist/lane departure warning: Lane Departure Warning.
(7Y3) Side assist/lane departure warning: Lane change assistant plus lane departure warning.
(8T0) Cruise control: Without cruise control system (CCS).
(8T1) Cruise control: Cruise control system (CCS).
(8T4) Cruise control: Adaptive Cruise Control.
(A8Q) Audi A8/S8 quattro
4L0.910.468.A.
7Y3+8T1.
PR-7Y1,7Y2,.
(AQ7) Audi Q7
306 -507-.
4L0.910.468.
4L0.910.468.A.
7Y3.
PR-7Y1.
PR-7Y1,7Y2,.
PR-8T4.
For vehicles with lane change for vehicles with cruise for vehicles with made by Audi. #4L0907468C
Stock Code 4E0907468H
The "H" Version that includes the "PR-8T4 + 7X8".
1103 -205-.
205 -1007-.
4E0.910.468.A.
PR-8T1.
PR-8T4.
PR-8T4+7X8.
(A8S) Equipment levels: Standard equipment.
(A8U) Equipment levels: Executive US equipment.
Software: for vehicles with parking aid for vehicles with cruise diagnosis made by Audi. #4E0907468H
See also
A8 ADAPTIVE CRUISE CONTROL Retrofit | Page 3 | Audi Forum
Your Gateway,
(A6) Audi A6/Avant
4F0 910 468 A.
4F0.910.468.A.
4L0.910.468.
4L0.910.468.A.
606 -907-.
907 -209-.
PR-8T1+7Y2.
PR-8T4.
PR-8T4+7X7.
4L0.910.468.A.
7Y3+8T1.
PR-7Y1,7Y2,.
(AQ7) Audi Q7
306 -507-.
4L0.910.468.
4L0.910.468.A.
7Y3.
PR-7Y1.
PR-7Y1,7Y2,.
PR-8T4.
1103 -205-.
205 -1007-.
4E0.910.468.A.
PR-8T1.
PR-8T4.
PR-8T4+7X8.
See also
#27
Can you please post a full auto scan and post it here.
I'm in my phone so don't have access to my pc to check part numbers of your gateway
Being a 4.2 tdi i am wondering if it's a dual Ecu car and need to code both 01 and 11
#28
4,2TDI (and 4,0TDI) and V10, W12 are all dual-ecu cars, both engine control units must be coded the same!
V6 (gas or TDI) and V8 gasoline are single ECU engines, no need for dual coding there.
#29
Dear all:
Thank you all for your quick replay!
Please find enclosed my scan:
________________________________________________
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E1 910 409 D HW: 4E1 907 409 A
Component: 4.2L V8TDI A000AGMª0020
Revision: --H05--- Serial number: AUX3Z0GN335850
Coding: 0011773
Shop #: WSC 65239 001 1048576
Readiness: 0 0 0 0 0
Coding: 0000001
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 J HW: 4E0 614 517 BQ
Component: ESP 5.7 allrad H49 0540
Coding: 0008557
Shop #: WSC 02313 000 00000
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 A
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0GN335850
Coding: 0410624
Shop #: WSC 02311 785 00200
Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 4
Fault Frequency: 0
Reset counter: 114
Mileage: 210880 km
Time Indication: 0
Date: 2016.01.01
Time: 17:41:00
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063968
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 300KI077590031
Coding: 0010010
Shop #: WSC 00000 000 08192
Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 H
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000136351
Coding: 0071771
Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Component: Sitzluefter BFS H02 010
1 Fault Found:
00066 - Right Rear Footwell Heater (Z43)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 114
Mileage: 210884 km
Time Indication: 0
Date: 2016.01.01
Time: 17:29:11
Freeze Frame:
Voltage: 11.50 V
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 S HW: 4E0 907 279 S
Component: ILM Fahrer H16 0240
Coding: 0143111
Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000035
Shop #: WSC 02313
Part No: 8K0 910 557
Component: REGENLICHTSENSORH04 0002
Coding: 00141886
Shop #: WSC 02313
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276V7900876
Coding: 0000001
Shop #: WSC 00493 211 83101
Address 11: Engine II Labels: Redir Fail!
Component: 4.2L V8TDI A000AGSª0020
Coding: 0011773 0011773
Part No SW: 4E0 910 561 E HW: 4E0 907 561 E
Component: ABSTANDSREGELUNGH01 X040
Coding: 0011168
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 154
Mileage: 210700 km
Time Indication: 0
Date: 2016.01.01
Time: 17:29:11
Freeze Frame:
Temperature: 18.0°C
Voltage: 13.70 V
Bin. Bits: 00000010
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 E HW: 4E0 959 655 K
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CU0005J5V
Coding: 0430707
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 B
Component: J0527 0410
Revision: 00H04000 Serial number: 90026073040038
Coding: 0012251
Shop #: WSC 00345 211 00000
Component: E0221 H02 0030
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 931 S HW: 4E0 920 931 S
Component: KOMBIINSTR. VDO H84 0610
Revision: D01 Serial number: AUDID3G5000141
Coding: 0000023
Shop #: WSC 21852 001 10485
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 265 081 T
Component: Heizgeraet H08 0140
Revision: 0000000C Serial number: 00000009013887
Coding: 0000111
Shop #: WSC 00000 000 00000
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 D
Component: KLIMA-STG. FOND 017 0230
Revision: 00000020 Serial number: 00000000062546
Coding: 0000000
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
Shop #: WSC 30471 264 92082
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4063978
5 Faults Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 114
Mileage: 210008 km
Time Indication: 0
Date: 2007.01.01
Time: 00:00:00
01447 - Sensor for Driver Seat; Height Adjust (G231)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 114
Mileage: 210040 km
Time Indication: 0
Date: 2015.12.29
Time: 09:21:48
01448 - Sensor for Driver Seat; Tilt Adjust (G232)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 114
Mileage: 210008 km
Time Indication: 0
Date: 2007.01.01
Time: 00:00:00
01916 - Lumbar Support Fore / Aft Adjustment Sensor (G375)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 114
Mileage: 210032 km
Time Indication: 0
Date: 2007.01.01
Time: 00:00:00
01479 - Sensor for Head-Rest Adjustment (G129)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 114
Mileage: 0 km
Time Indication: 0
Date: 2007.01.01
Time: 00:00:00
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
Component: MNS ECE H52 1060
Revision: 00000000 Serial number: 364G+067579663
Shop #: WSC 35084 142 84113
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000731000110
Coding: 0003236
2 Faults Found:
00510 - Motor for Wind Deflector (V252) (DISCONNECTED BY ME)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 0
Fault Frequency: 2
Reset counter: 114
Mileage: 210884 km
Time Indication: 0
Date: 2016.01.01
Time: 17:39:00
02148 - Front Reading Lamp Button (E328); Right
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 114
Mileage: 210884 km
Time Indication: 0
Date: 2016.01.01
Time: 17:40:00
Address 42: Door Elect, Driver Labels: None
Part No SW: 4E1 910 802 B HW: 4E1 959 801 F
Component: Türsteuer.FS BRM005 0180
Coding: 0028589
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 E HW: 4E0 907 289 E
Component: Komfortgeraet H10 0030
Revision: 00300010 Serial number: 00000711190293
Coding: 0004728
Part No: 4E0 910 853
Component: Heckdeckel P27H08 0090
Part No: 4E0 907 719
Component: Neigungssensor H05 0020
1 Fault Found:
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 254
Reset counter: 114
Mileage: 206856 km
Time Indication: 0
Date: 2015.05.06
Time: 08:31:05
Address 47: Sound System Labels: Redir Fail!
Part No SW: 4E0 910 224 B HW: 4E0 035 223 H
Component: Amp.-Basis H41 0150
Revision: 00000000 Serial number: 00000077521576
Coding: 0000002
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 D
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000010807
Coding: 0010101
Address 52: Door Elect, Pass. Labels: None
Part No SW: 4E1 910 802 B HW: 4E1 959 802 F
Component: Türsteuer.BF BRM005 0180
Coding: 0028589
Address 53: Parking Brake Labels: 4E0-910-801.lbl
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0001031
Shop #: WSC 00493 211 03085
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000018
Part No: NOSUBSYSTEM
Component: AFS-Modul links
Component: AFS-Modul rechtsH01 0010
1 Fault Found:
02233 - Left Headlight Power Output Stage (J667)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 114
Mileage: 210888 km
Time Indication: 0
Date: 2016.01.01
Time: 17:39:58
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 396K2077584085
Coding: 0000001
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 E HW: 4E0 919 148
Component: R78 TVHybridDVB 0470
Revision: R0H06000 Serial number: 76300801028202
Coding: 0000001
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000017122
Shop #: WSC 32590 126 86229
Part No: 4E0 915 105 A
Component: von VA0 2711092222
Coding: 344530393135313035412056413032373131303932323232
Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0028589
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0028589
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 0
Reset counter: 113
Mileage: 210656 km
Time Indication: 0
Date: 2015.12.30
Time: 15:01:40
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08740730400845
Coding: 0201008
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005272443
Coding: 0010900
Shop #: WSC 06335 000 00000
1 Fault Found:
02454 - Microphone Unit (in Front Roof Module) (R164)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 114
Mileage: 210884 km
Time Indication: 0
Date: 2016.01.01
Time: 17:36:04
End ---------------------------------------------------------------------
#30
In Address 02 I measured measuring block 125 and 126
accordingly this document:
Address 02:
Coding: 0000001
No fault code found!
All communication is OK. (I guess ;-))
Address 02:
Coding: 0000001
