Sponsored by:
Sponsored by:
Trunk light Led swap
Old 09-13-2010, 01:36 PM
AEinaD3's Avatar
Default Trunk light Led swap
So my LED's came in this afternoon an I raced to put them on..
It's a simple process, took 5min or so to complete.
Tools:
Flathead Screwdriver (small).
Before:
Slide the screwdriver to the side of the housing, an pop it out.
Pic already has the LED (sorry got impatient)
Once you have it out just pull out the bulb (VERY HOT) an replace with LED.
After:
Old 09-13-2010, 06:55 PM
tashakes's Avatar
Here we go, more leds..... alrite, what kind did you use? So now I have to do the puddle lights, trunk lights and driving lamps (I already received these).
Nice write up
Old 09-13-2010, 08:41 PM
Brozee's Avatar
Can you link us to the site that you bought the LED's from and exactly what ones?
Old 09-13-2010, 08:50 PM
Brozee's Avatar
As well, I am planning on doing the DRL's, license plate LED's, inner trunk LED's as well as driver and passenger lower trim LED's.
Old 09-14-2010, 09:19 AM
AEinaD3's Avatar
http://autolumination.com/194.htm
High Powered 5050 3 Chip SMT Leds - Outfitted with Canbus Bulb-Out Warning Cancellation Chip
Designed to eliminate most electronic bulb-out warnings in BMW, Mercedes, AUDI, VW, Volvo, and most others.
4LED 12mmx30mm $9.99 each
Those are used for the trunk (inside) AND the Puddle lights/under the door..
1led 9mmx22mm $7.99
Those are for your parking lights
NEXT project are for my FOGGIES to be converted to HID..
Does anyone else with a D3 have Projectors in there FOG light?
MINE DO, I remember when greenojos, A8LOONG, Theif came out to get their D3's dropped, we noticed My 04' had Projectors as theres did not, an there was an O5'/06'D3 in the mix..
Old 09-14-2010, 11:16 AM
Brozee's Avatar
Pretty positive I don't have projectors in my fogs, mine are actually in need of cleaning the surface of the light is a bit grimy to be honest. But you can never tell because it doesn't distort the light and you can only see it when close close up.
Old 09-15-2010, 05:49 AM
itdoesitallroad's Avatar
For those of us with the new style grille. Getting to the drivers side headlight requires removal of the the power steering resivoir. Found that out the hard way while I was following the write-up for the parking light LED conversion write up.
Old 09-15-2010, 11:32 AM
mikesd1980's Avatar
Tools:
Before:
After:
Are you going to try a LED bulb swap out for the inside interior lights?
Old 09-16-2010, 05:30 AM
AEinaD3's Avatar
I might, havent decided yet though.
Old 09-16-2010, 03:17 PM
mikesd1980's Avatar
I have a friend who did it on is Acura TL and it looks really nice. I dont know how easy it will be to do the the LED bulbs in the inside. I am hoping that you would try it first :-).
So far I did the DRL's and door lights. I am having trouble with the license plate lights because one side the screw is rust & stripped(I have to break out the dremel. Its still packed with my other tools) and the other side dont have a screw and hard to come off. I will figure it out soon though.
Quick Reply: Trunk light Led swap
