ABS control module defective?
me again!
problem of the week: ABS module defective?
car: 2005 audi A8
so while my car was in last week getting the timing belt done and fuel pump, now a mysterious
ABS code that won't go away. i unplugged the battery at one point and connected the two terminals
together for a cap discharge. when i hooked it back up, this problem seemed to show up at the same
time.
tried clearing it countless number of times, came back right away. also my steering angle sensor was
popping up a code, but i went through the re-coding/basic settings of it and the error went away. i tried
also recoding the ABS module from the instructions on the ross-tech site, but that didn't seem to do anything.
00003 - Ross-Tech Wiki
they also said try turning off and on the ignition and clearing the codes three times, but that didn't seem to
work. what are the chances that the ABS module died as well?! PANIC ATTACKS.
so now, ESP, ABS, parking brake, headlight range control are all not working. ABS light and ESP light on the
dash are lit at all times.
here's a log of my whole autoscan...
Monday,02,March,2015,15:27:03:02791
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.1.1
Data version: 20150130
VIN: WAUML44E85N007629 License Plate: N88GML
Mileage: 171470km-106546mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 28 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAUML44E85N007629 Mileage: 171470km-106546miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 1010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: Sporadic communication error 1000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 J HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0D7749270
Coding: 0007773
Shop #: WSC 94754 999 83973
VCID: 2855C2139BF9FC61060-807D
2 Faults Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 -
19468 - Relay for Fuel Pump 2 (J49)
P3012 - 004 - Open or Short to Ground - Intermittent
Readiness: 0000 0100
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 S HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0020
Revision: --H01--- Serial number: 0043997
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 3261207BAD2586B1A84-8067
1 Fault Found:
18259 - Powertrain Data Bus
P1851 - 000 - Missing Message from ABS Controller - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 36
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 02:00:37
Freeze Frame:
RPM: 672 /min
RPM: 640 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 60.0*C
T.B. Angle: 0.0*
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H50 0510
Coding: 0007597
Shop #: WSC 94754 000 00000
VCID: 2241D03BFDC51631584-8077
2 Faults Found:
00003 - Control Module
014 - Defective
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
012 - Electrical Fault in Circuit
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 D
Component: FBS AUDID3 H04 0140
Revision: 01404004 Serial number: AUX3Z0D7749270
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58B5B2D3EB198CE1760-800D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
No fault code found.
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940576
Shop #: WSC 00000 785 00200
VCID: 234FD53FE2DF1F39532-8076
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 S HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 346HU047513845
Coding: 0000103
Shop #: WSC 94754 999 128345
Subsystem 1 - Part No: 4E0 910 609 A
Component: Bedienteil MMI H42 0020
Subsystem 2 - Serial number: 317IP047537241
Subsystem 3 - Serial number: 7408.09.0400000000217B0046ÿ
Subsystem 4 - Serial number: 7B0046ÿ
1 Fault Found:
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 170
Time Indication: 15
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 A HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 016 0340
Revision: 00000027 Serial number: 00000000053025
Coding: 1151313
VCID: 1B3FEDDFDAAF27F99B2-804E
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO27072004065A000000000093ÿ† 89
Subsystem 5 - Serial number: 000093ÿ† 898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO27072004065A00000000
Subsystem 7 - Serial number: 65A000000000123ÿ
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 J HW: 4E0 907 279 J
Component: ILM Fahrer H12 0190
Coding: 0123104
VCID: 2F67290FBE17AB59C7A-807A
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000034
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBD4029407
Shop #: WSC 00000 000 00000
VCID: 1C3DEEC3DFA120C1928-8049
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
VCID: 244DD623E7D118012A8-8071
3 Faults Found:
01587 - Igniter 2 for Airbag; Drivers Side (N250)
002 - Lower Limit Exceeded - MIL ON
01743 - Igniter for Knee Airbag; Pass. Side (N296)
001 - Upper Limit Exceeded - Intermittent - MIL ON
00588 - Airbag Igniter; Driver Side (N95)
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0012141
VCID: 65CB8B27AC6B2109FD6-8030
Component: Lenkradmodul H05 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 J HW: 4E0 920 900 J
Component: KOMBIINSTR. VDO H49 0200
Revision: D03 Serial number: AUDID3D8002412
Coding: 0016338
Shop #: WSC 53595 000 1048576
VCID: 2649CC2B91EDEA1134C-8073
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0040
Revision: 07 Serial number: 05005047091EFC
Coding: FCFE7FDD1B2304
4 Faults Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 20
Reset counter: 134
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 01:55:10
00461 - Control Module for Seat Memory; Passenger (J521)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 36
Reset counter: 174
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 01:58:53
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 170
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 02:00:37
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 170
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 02:05:04
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
Freeze Frame:
Fault Status: 01100001
Fault Priority: 4
Fault Frequency: 0
Reset counter: 134
Mileage: 171472 km
Time Indication: 0
Date: 2015.03.01
Time: 15:15:06
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 A
Component: KLIMA-STG. FOND 015 0210
Revision: 00000016 Serial number: 00000000021137
Coding: 0000000
VCID: 61C39F37B8434D2901E-8034
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 02:00:39
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H08 0060
Coding: 4071658
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H43 1100
Revision: 00000000 Serial number: 355FQ047528414
Shop #: WSC 94754 999 15543
VCID: 387512534B596CE1960-806D
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 170
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 02:00:41
Freeze Frame:
Bin. Bits: 1100
02927 - DVD Read Error
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 4
Reset counter: 172
Mileage: 171388 km
Time Indication: 0
Date: 2015.02.27
Time: 20:02:02
Freeze Frame:
Hex Value: 0x54F1
Hex Value: 0xFAF6
Hex Value: 0x0401
Hex Value: 0x0000
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H02 0090
Serial number: 00000420700097
Coding: 0003477
VCID: 1D3BE3C7C4BB29C9656-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM002 0060
Coding: 0028204
VCID: 2045DA33F3C904214E0-8075
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 9
Reset counter: 174
Mileage: 171376 km
Time Indication: 0
Date: 2004.03.26
Time: 01:59:52
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040409080252
Coding: 0065086
VCID: 2757C12F96E7F3190FA-8072
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P27H08 0090
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H03 0020
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 02:00:38
Address 47: Sound System Labels: None
Part No SW: 4E0 910 224 C HW: 4E0 035 223 B
Component: DSP-High D3/AUX H13 0470
Revision: Dev_D01 Serial number: 00000000200466
Coding: 0000016
Shop #: WSC 94754 999 999999
VCID: 1E39E4CBC9BD32D17CC-804B
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 170
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 02:00:38
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000047213
Coding: 0010111
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T0F3ZE
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 02:00:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM002 0060
Coding: 0000000
Shop #: WSC 02311 000 00000
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 9
Reset counter: 174
Mileage: 171376 km
Time Indication: 0
Date: 2004.03.26
Time: 01:59:52
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000532
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 171384 km
Time Indication: 0
Date: 2004.03.26
Time: 02:00:37
Freeze Frame:
Voltage: 13.66 V
Count: 242
008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 3
Fault Frequency: 54
Reset counter: 134
Mileage: 171384 km
Time Indication: 0
Date: 2004.03.25
Time: 18:38:08
Freeze Frame:
Voltage: 13.46 V
Count: 231
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 37
Time Indication: 0
Freeze Frame:
Voltage: 10.25 V
Count: 61
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Revision: 00000001 Serial number:
Coding: 0000001
VCID: 62C1903BBD455631184-8037
2 Faults Found:
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 0
Reset counter: 174
Mileage: 171384 km
Time Indication: 0
Date: 2004.03.26
Time: 01:56:52
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 174
Mileage: 171384 km
Time Indication: 0
Date: 2004.03.26
Time: 01:56:52
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 B
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 304IL047601087
Coding: 0000002
VCID: 31632F77A823BDA9D1E-8064
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H11 0510
Revision: 00000000 Serial number: 00000000007956
Subsystem 1 - Part No: 666 666 666 6
Component: von MLA 0049854996
Coding: 36363636363636363636204D4C4130303439383534393936
Shop #: WSC 12345 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM002 0060
Coding: 0028204
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010027 Serial number: 00000700026376
Coding: 0232125
VCID: 5FC799CF8E377BD937A-800A
1 Fault Found:
01521 - Sensor for Tire Pressure
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 130
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 01:57:26
Freeze Frame:
Speed: 0.0 km/h
Temperature: -7.0*C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM002 0060
Coding: 0028204
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616 B
Component: Telematik USA1 0080
Revision: 00000004 Serial number: 0000ATD3012100
Coding: 0000005
Shop #: WSC 94754 999 00336
VCID: 60C59A33B04944210E0-5122
2 Faults Found:
01531 - Emergency Battery
012 - Electrical Fault in Circuit - MIL ON
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08730425102671
Coding: 0001208
VCID: 2143DF37F8C30D2941E-8074
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 170
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 02:00:38
End-------------------------(Elapsed Time: 04:10)--------------------------
Address 17: DTCs cleared
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 05: DTCs cleared
Address 06: DTCs cleared
Address 07: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 0E: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 19: DTCs cleared
Address 25: DTCs cleared
Address 28: DTCs cleared
Address 34: DTCs cleared
Address 36: DTCs cleared
Address 37: DTCs cleared
Address 38: DTCs cleared
Address 42: DTCs cleared
Address 46: DTCs cleared
Address 47: DTCs cleared
Address 4F: DTCs cleared
Address 52: DTCs cleared
Address 53: DTCs cleared
Address 55: DTCs cleared
Address 56: DTCs cleared
Address 61: DTCs cleared
Address 62: DTCs cleared
Address 65: DTCs cleared
Address 72: DTCs cleared
Address 75: DTCs cleared
Address 76: DTCs cleared
i think we're all going to be great friends guys!
thanks
paul
car: 2005 audi A8
time.
Coding: 0007773
2 Faults Found:
P1653 - 008 -
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 36
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 02:00:37
Freeze Frame:
RPM: 672 /min
RPM: 640 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 60.0*C
T.B. Angle: 0.0*
Coding: 0007597
2 Faults Found:
014 - Defective
Coding: 0410624
Component: ELV XXXX
Coding: 3940576
Coding: 0000103
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 170
Time Indication: 15
Coding: 1151313
Coding: 0123104
Coding: 00000034
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Coding: 0530707
3 Faults Found:
Coding: 0012141
Coding: 0016338
4 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 20
Reset counter: 134
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 01:55:10
Freeze Frame:
Fault Priority: 2
Fault Frequency: 36
Reset counter: 174
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 01:58:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 170
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 02:00:37
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 170
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 02:05:04
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 134
Mileage: 171472 km
Time Indication: 0
Date: 2015.03.01
Time: 15:15:06
Coding: 0000000
Coding: 0015510
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 02:00:39
Coding: 4071658
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 170
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 02:00:41
Freeze Frame:
Bin. Bits: 1100
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 172
Mileage: 171388 km
Time Indication: 0
Date: 2015.02.27
Time: 20:02:02
Freeze Frame:
Hex Value: 0x54F1
Hex Value: 0xFAF6
Hex Value: 0x0401
Hex Value: 0x0000
Coding: 0003477
Coding: 0028204
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 9
Reset counter: 174
Mileage: 171376 km
Time Indication: 0
Date: 2004.03.26
Time: 01:59:52
Coding: 0065086
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 02:00:38
Coding: 0000016
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 170
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 02:00:38
Coding: 0010111
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 02:00:00
Coding: 0000000
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 9
Reset counter: 174
Mileage: 171376 km
Time Indication: 0
Date: 2004.03.26
Time: 01:59:52
Revision: AV1C1010
Coding: 0000532
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 171384 km
Time Indication: 0
Date: 2004.03.26
Time: 02:00:37
Freeze Frame:
Voltage: 13.66 V
Count: 242
Freeze Frame:
Fault Priority: 3
Fault Frequency: 54
Reset counter: 134
Mileage: 171384 km
Time Indication: 0
Date: 2004.03.25
Time: 18:38:08
Freeze Frame:
Voltage: 13.46 V
Count: 231
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 37
Time Indication: 0
Freeze Frame:
Voltage: 10.25 V
Count: 61
Coding: 0000001
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 174
Mileage: 171384 km
Time Indication: 0
Date: 2004.03.26
Time: 01:56:52
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 174
Mileage: 171384 km
Time Indication: 0
Date: 2004.03.26
Time: 01:56:52
Coding: 0000002
Coding: 0028204
Coding: 0232125
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 130
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 01:57:26
Freeze Frame:
Speed: 0.0 km/h
Temperature: -7.0*C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0028204
Coding: 0000005
2 Faults Found:
Coding: 0001208
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 170
Mileage: 171388 km
Time Indication: 0
Date: 2004.03.26
Time: 02:00:38
thanks
paul
Let's back up a step please. Questions:
I have answered lots of questions here along the way. But, this is kind of a parade of one thing after another. Reading this, I have some ideas, but I also see some kind of "no no's" in what you did. Thus, please answer some questions:
1. what is the basic general history of this car? Where did you get it? It it a normal used car, a salvage, or what?
2. Do you have any maintenance/historical records?
3. Do you own a service manual? If not, what's the plan?
yeah, well, looks like i'm not having a good month with this car. since this whole heating fiasco, it's been one sh*t storm
after another.
1. this was a normal used car. i bought it in july of 14, and have basically driven it up to this point without any issue a vagcom couldn't fix.
2. no, i do not have any maintenance/history on the service. i tried going to to dealer to see if i could get a copy
of the history of it and they said they could only give it to the original owner of the car? i wasn't entirely satisfied with
that response, but i haven't pursued it further.
3. i do not have a service manual for this car. i came off a 7 year ownership of a D2 and didn't really have many problems
with that car, but now seeing with this one - looks like i'm going to be in the market for a service manual.
So ideas and steps/to do's....
Punch line being that yes you may have lost/blown the ABS. And yes, you need a manual for this car. Especially if you may be on the way to a grand for an ABS module, or whatever they cost. But, some ideas first:
1. Notice all your codes around it have 2004 dates, not 2014 dates like various others I see. Are you clearing codes at the individual module level, or just trying the global clear from the VCDS screen? My (and some others') experience is often you have to do them inside of a module to get it to clear fully.
2. I personally never heard of touching two battery terminals together on an Audi, but oh well. In theory you would think it shouldn't matter w/ no power but then I also can't think of where there is a capacitor of any consequence in the system either. I can say it isn't in the manuals anywhere, and we know from another thread going on there is a battery in the alarm horn at least, so system may not like that approach. Nothing to be done now though.
3. Did you run the self test for ABS in VCDS? If not, do NOT in any early diagnostic phase. It can blow it up from my experience. But if you did, also fess up. I ask because you talk about trying to recode it.
4. After dealing with above, try obvious easy stuff like unplugging ABS controller and then plugging back in (power off) see if anything happens.
5. Your steering angle, ESP, and airbag light combo caught my eye by chance, coupled with two of your three airbag codes (ignoring the passenger knee one; in that case check the connector and apply DeOxit type stuff). What is in common to all of those is the steering wheel clock spring. To be clear, the two driver ignitors referenced are both in the main driver's airbag horn area; they aren't the seat one or the knee one given the code particulars. The clock spring part is pricy, and sometimes I find it is just a connector at the back of the ring (there are two in back IIRC) that has backed off/isn't locked down correctly. Thus you can try pulling the steering wheel trim and then trying to check those connectors for firmness. If it isn't the connectors, it is logically then the clock spring unit (which includes the angle sensor). That needs to be in order to deal with a bunch of your codes and lights in any case.
6. Have you driven the car BTW? Like down the road? I ask because to clear the angle sensor code, which I get commonly after disconnecting the battery, I have to drive it basically down the block and turn the steering wheel a bit. Only then does it go away, which in turn clears other codes. Thus, this simple one can keep an ESP fault (or perhaps an ABS one; I don't recall) going when all you need to do is drive a few hundred feet for sensor to reset.
7. Your rear brake code looks stale. What I notice is the voltage is low, which doesn't tie to other voltage reading in your scan that are normal. Try recoding brake pads again. Do it 100% by the book. Including the specific step where you have to cycle the ignition key/VCDS. I mention it since it still has to do with brakes, like ABS. Try to get it out of there (assuming your pads aren't in fact shot).
8. Deal with your rear sensor ABS code. Check the sensor, connector, etc. Obviously you have to resolve that to clean up ABS anyway.
9. And finally, see if ABS is still coding and trouble lights are still on on after all this stuff--including getting to bottom of airbag and angle sensor codes and light since they are in common with the clock spring and that in turn is crucial for ESP. At that point if you still have codes and lights, ABS is looking more like it is DOA. Plus, you have a code that dead nuts says it is defective. If you did run the self test, I bet it may have fried anyway. Still, yes try to recode. Disconnect battery for that matter too and then simply reconnect. But if and only if you have done all the other stuff, then consider running ABS self test. Since I've seen it blow up modules before (or maybe they were blown in reality), I wouldn't do it early. But if it still codes out as defective, you have your unfortunate (and pricy) diagnostic answer.
1. yeah, i never noticed that? how come the dates say 2004? i did a whole auto scan of the whole car, but generally i'll do scans in the each module. like for the ABS, i was trying to erase the code
directly from the 03 module.
2. that was when i was trying to diagnose the fuel pump. first instinct on this car malfunctioning is something electrical, all the mechanics at my work throwing in their 2 cents,
i know i shouldn't listen to anybody. haha
3. no, well i don't recall running any tests in the ABS system. but during my whole fuel pump fiasco, when the job was done i reconnected the battery
terminal and this is when the errors showed up. the first VCDS scan indicated there was an error is my steering angle sensor. i did a reset procedure i found
on ross tech website and that worked out fine. that error went away, but the ABS/ESP light is still on.
4. when you say unplug abs controller as in the locking cabled harness that attaches into the ABS pump? yes, i tried that. left it off for 30 mins, no change.
5. pass air bag was on because the glove box is out and it's disconnected. when i bought the car actually the airbag light was on, and that error indicates n250
air bag igniter. i did find that some people have said to clean/replug the connector, but i just haven't gotten around to it. it's on the list.
6. driven the car about 50 km's in the past two days. i was hoping a drive might wake the module up or something, but nothing as of yet.
7. the brake pad warning has just showed up within the past couple of weeks. haven't had time to dig into that.
i mean yeah i get it, these modules can go. i'm just thinking since this car went through the ringer the past week - fuses pulled from the dash
(i checked to make sure they we're good and properly seated again) fuel pumps, batteries, timing belts, heater cores - just maybe it causing
something not to work properly. everything was more or less fine last week, and since i disconnected the battery it's christmas. i'm just hoping
it's some sort of software setting/programming.
okay, so i did a re-scan. the results are enclosed lower in this post.
the guys down the street have a full ABS module that he lent me to try out.
now, here's my question. if i unplug my current module and plug in this one he gave me (just plugging it in,
not replacing) is this something i could do to see if the car detects it? with this way can i confirm if it's an actual module
problem, not some sort of software/coding problem?
i figured if i plug in the other one he gave me and if i can erase the DTC and it doesn't come back then
i can know for SURE that it needs to replaced? is this suggestible or will something blow up?
here's my scan from last night.
Saturday,07,March,2015,19:14:45:02791
VIN: WAUML44E85N007629 License Plate: HEATSCAN
Mileage: 171610km-106633mi Repair Order:
VIN: WAUML44E85N007629 Mileage: 171610km-106633miles
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 1010
07-Control Head -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: OK 0000
37-Navigation -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
Coding: 0007773
1 Fault Found:
P1653 - 008 -
Readiness: 0110 1101
Coding: 0000002
Coding: 0007597
Shop #: WSC 12345 000 00000
1 Fault Found:
014 - Defective
Coding: 0410624
Component: ELV XXXX
Coding: 3940576
Coding: 0000103
Coding: 1151313
Coding: 0123104
Coding: 00000034
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Coding: 0530707
Coding: 0012141
Coding: 0016338
Coding: 0016338
Coding: 0410624
Component: ELV XXXX
Coding: 0000000
Coding: 0015510
Coding: 4071658
Coding: 0003477
Coding: 0028204
Coding: 0065086
Coding: 0000016
Coding: 0010111
Coding: 0028204
Revision: AV1C1010
Coding: 0000532
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 93
Reset counter: 145
Mileage: 171384 km
Time Indication: 0
Date: 2004.03.25
Time: 18:38:08
Freeze Frame:
Voltage: 13.46 V
Count: 231
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 37
Time Indication: 0
Freeze Frame:
Voltage: 10.25 V
Count: 61
Coding: 0000001
1 Fault Found:
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 145
Mileage: 171608 km
Time Indication: 0
Date: 2015.03.06
Time: 19:03:46
Coding: 0000002
Coding: 0028204
Coding: 0232125
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 145
Mileage: 171615 km
Time Indication: 0
Date: 2015.03.06
Time: 19:04:19
Freeze Frame:
Speed: 0.0 km/h
Temperature: -9.0*C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0028204
Coding: 0000005
VCID: 60C59A33B04944210E0-5140
1 Fault Found:
Coding: 0001208
End-------------------------(Elapsed Time: 04:55)--------------------------
thanks
Coding: 0007773
1 Fault Found:
P1653 - 008 -
Coding: 0000002
Coding: 0007597
1 Fault Found:
014 - Defective
Coding: 0410624
Component: ELV XXXX
Coding: 3940576
Coding: 0000103
Coding: 1151313
Coding: 0123104
Coding: 00000034
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Coding: 0530707
Coding: 0012141
Coding: 0016338
Coding: 0016338
Coding: 0410624
Component: ELV XXXX
Coding: 0000000
Coding: 0015510
Coding: 4071658
Coding: 0003477
Coding: 0028204
Coding: 0065086
Coding: 0000016
Coding: 0010111
Coding: 0028204
Revision: AV1C1010
Coding: 0000532
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 93
Reset counter: 145
Mileage: 171384 km
Time Indication: 0
Date: 2004.03.25
Time: 18:38:08
Freeze Frame:
Voltage: 13.46 V
Count: 231
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 37
Time Indication: 0
Freeze Frame:
Voltage: 10.25 V
Count: 61
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 145
Mileage: 171608 km
Time Indication: 0
Date: 2015.03.06
Time: 19:03:46
Coding: 0000002
Coding: 0028204
Coding: 0232125
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 145
Mileage: 171615 km
Time Indication: 0
Date: 2015.03.06
Time: 19:04:19
Freeze Frame:
Speed: 0.0 km/h
Temperature: -9.0*C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0028204
Coding: 0000005
1 Fault Found:
Coding: 0001208
thanks
I bet you still don't have Bentley....? Feeling Lucky...?
So, here's your clear shot--at either Bentley or a really expensive paperweight. End of internet idea, or if you do good luck on relying on it. The $64 question (actually more like $640 or maybe a grand plus ) is whether you can just separate the electronics from the solenoid assembly. Given you have a presumably good unit in hand, that is Audi parts gold. Well, we know one other poster was busy trying to repair his electronics too, but then we also know his is basically DOA from another thread in last few months. I know I could do it on my C5, but that was a prior mid-90's design lock in, akin to D2 and was also pre-ESP. So, are you feeling lucky? To be clear, no way I would risk testing it loose (electronics separated from unit), and no idea what would happen if you plug in a complete unit that isn't hooked up hydraulically.
Or, you could buy Bentley (or use it if you have it) and look up whether the electronic part can just be separated off, and if so, how to. I would only do it via direct service procedure confirmation myself and with the Bentley I have, would not rely on other posts that are not 100% validated first person successful experience specific to a D3, and definitely not a D2, C5, C6, B whatever. And no, I would not even begin to disconnect all the brake lines and the bleed it all if I don't have to to swap the whole thing in.
And BTW, no idea on coding thiese things either. Bentley...
AudiWorld Wiseguy
Something not right with that scan. The summary at the top doesn't match the details.
Clear all codes, switch car off, get out and lock it. Leave it for 20 mins to ensure all systems go to sleep. Then go for a drive, town and highway for 20-30 miles, including a few full throttle runs up to a good speed, a few emergency stops (enough to trigger the abs to check it works), then run another scan and see what you get. A good old fashioned Italian tuneup!
PeteKOC (12-13-2022)
i did find some icy patches to do some hard stops on and i can feel some SLIGHT pedal pumping but
it's not full functional that's for sure.
i tried beating it too. shhhhhh, don't tell anyone here.
