Air bag light reset procedure (anyone try this?)
AudiWorld Expert
My airbag light came on 2 weeks ago. It is throwing the same code as described in the links provided below:
<font color="red">Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
Shop #: WSC 02313 785 00200
VCID: 244CFA939E5D
2 Faults Found:
00588 - Airbag Igniter; Driver Side (N95)
002 - Lower Limit Exceeded - MIL ON
01587 - Igniter 2 for Airbag; Drivers Side (N250)
002 - Lower Limit Exceeded - MIL ON</font>
I suppose unless someone here tells me this will turn my car into a bomb, I am going to give it a shot.
http://forums.vwvortex.com/showthread.php?2815467
http://www.audizine.com/forum/showth...%28Audi-TSB%29
Coding: 0530707
VCID: 244CFA939E5D
2 Faults Found:
N95 and N250 are for the steering wheel airbag, I am not sure that the issue will be fixed with the above links. My niece's Jetta had the same issue, but it was a seatbelt fault, so I did that procedure and it worked.
It seems that you have a problem either with the module, the airbag or the connections to the airbag.
AudiWorld Expert
You appear to be correct. I called the dealer, asked them about a TSB for airbags and they confirmed that they are hardwiring the plug under the seat and of course told me not to do it.
I did it. It didn't work. LAME.
Ever since I moved to the colder climate it has been one thing after another.
procedure
3 months ago I would call this thread the dumbest thing I read, nowadays after reading most of the threads here I would say is just average.
the fix they talk there is for the side air bag only and is not actually recommended, the problem you have is with the driver's air unit, which before you cut any wires should try to reset first.
my .02
my .02
AudiWorld Expert
my .02
my .02
Scenario
First, this is something you read somewhere and try hoping it would fix your light, correct?
second, did you even bother to find out about what the fault number refers to? definitely not
keep trying everything you read it may eventually work.
whenever the native americans danced the rain dance always rained, you know why?
because they never stopped dancing until actually rained.
AudiWorld Expert
Well if you are Jose... then the same people that trained you, trained the people that confirmed the technique. Besides, bypassing a connector is hardly an issue.
So by bothering to find out what the fault referred to...yes, I did try. And I will keep trying things until it rains.
Rain
first as I said try to reset (which you stated already done), second I would remove the unit from the steering, there,s two connectors there, be careful not to pull them as damage to the spiral ring will ocur, try unplugging and plugging them again and reset the fault, this works most of the time as connectors sometimes lose continuity.
remember to touch a solid piece of metal in the car like the door striker to ground yourself and avoid a static discharge.
better yet let somebody who knows what is doing handle it.
Yes am Jose and was not trained by Audi, I was trained by an engineering company that also happens to make some amazing cars.
my boys would never suggest you to do that.
TTsumibishi
11-01-2008 08:45 AM
