Air box question
Air box question
Hey im new to the audi world lol. Im trying to connect my air filter box to the bumper tube so it can get fresh air instead of engins bay heat. There is a little black adapter that is missing on my A8. Does anyone know what this piece would be called??
https://www.ecstuning.com/ES382361/
I just bought one a few months ago to install after finding my original one to be torn. The new ones aren't any less of a PITA to install.
Replaced mine a year ago
The original was deformed and was a 30 minute job to reinstall. Usually it was shifted and not sealing again at the next oil change.
Finally purchased a new one and was a little fiddley getting it installed correctly the first time.
After a few heat soaks it set in the proper shape and reinstalling is a 3 minute job. Sure beats fighting the old one.
Just verify a new one is installed properly the first time. If not after many heat cycles it may set in the wrong shape.
On my 2005 the air box has to be pulled to change the oil filter.
Another try
I think the underhood temps here in Houston are 100 degrees higher than water.
Do know that using a little lube to get correctly seated the first time was the ticket. It goes right on and is still attached properly at the next oil change.
You might consider ordering another. Wish I had after the first oil change. Would spend 30 minutes fighting it. And it would pull loose soon after. That was the worst part of an oil change.
Now it is threading all the zip ties for my ragged belly pan.
Buy one
I used to get agrevated fighting the original. People told me it was upside down, reversed, backwards, and every other wrong install. But is was warped from someone not reinstalling properly and permantly warped.
Waited a year to purchase a new one. I would buy one every oil change. Life is too short to let a 50 cent plastic part beat you down.
I fought it more than most, been changing the oil at 4,500 - 5,000 mile intervals since getting the car. It looks like it is ready to be changed then.
