Air Suspension Compressor Rebuild Kit Available
#31
anyone know if the brass air line fitting is
single use ? meaning cant be reused.
I got pump working and it blew air line fitting right off. it doesnt seem to tighten though flush with motor body.
arnott how-to guide says remove fitting and discard.
I can only guess I need to buy a new fitting as they are single use ????
#32
Suspension System is draing my battery with ignition off
Can anyone help me with pics. I have a good battery but it drains in a few hours after ignition is turned off. A mechanic wired the fuse box so that the system only works when the ignition is on. ( fuses box calls it navigation system ) but it is the up and down system. I still do not know if that will work. I think I have a sticky relay. Can anyone tell me where the conrtol system is for the suspension system and if there is a rely and where would it be located 9 pictures if possible) I have a 2001 Audi Allroad. Replaced the front bags a year ago.
mraiteri@aol.com
mraiteri@aol.com
#33
I got pump working and it blew air line fitting right off. it doesn't seem to tighten though flush with motor body.
The manual is fairly specific re dimensions of the amount of tubing to allow to project and it's surprisingly large.
Good luck,
Tom
Pmpsch
Q7 MKII Discussion
14
12-06-2015 01:14 PM
Audi A8 2005 Audi A8L
Jan_PL_S6
12
11-27-2015 07:27 AM
