Air Suspension Issue
I have read many threads on this. Resolutions seem to be compressor, struts, relay, or control unit. Folks talk about spraying hoses, struts, and other with soapy water and watch for bubbles to find leaks. (Don't know how I would see anything the way things are packed in, but will certainly try)
I sometimes get the amber and/or green warning light on dash ( which usually goes out after my commute is over, or by the next day). I have never heard any air leaking and the compressor has never continued running (Until Now) compressor running, (no air leak that I can hear). I don't believe I have strut problem as corners have not dropped. The car doesn't always lower and release air when I shut off as I have heard from some people.
I have been tracking issue for about a week.
• 2/4/16 - Car parked and left running, get back in after 2 minutes and amber and green lights are on.
• 2/5/16 - Start car no lights on and no issues
• 2/6/16 - Car parked and left running get back in after 5 minutes and Green light comes on after driving 1 block.
• 2/7/16 - Started car and the level raised and green light went out.
• 2/9/16 - Get off freeway and after about 300 yards the "Up Arrow" turned Whit and the drive mode changed from "Auto" to "Dynamic", Green light on. Got home parked car, shut off and restarted. I changed mode back to "Auto" and the light went out and the car lifted.
• 2/10/16 - Once again got off freeway and after about 300 yards white "Up Arrow" stayed on this time and the pump continued to run until i got home and shut off the car. When I restarted it was in "Dynamic" mode and pump was off. Now if I try changing it to any other mode or lift the pump runs but nothing happens.
Might this be an electrical issue? Relay or control unit? I have rebuild kit arriving this weekend for the air compressor.
Any help with this would be greatly appreciated. Today's scan below.
Wednesday,10,February,2016,16:28:01:00255
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
Ross-Tech: Home
VIN: WAUMV44E77N001141 License Plate:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUMV44E77N001141 Mileage: 171560km-106602miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 079-907-560-BVJ.clb
Part No SW: 4E1 910 560 A HW: 4E1 907 560
Component: 4.2l V8/4V 0040
Revision: --H16--- Serial number: AUX3Z0F4794727
Coding: 01060009190F0120
Shop #: WSC 02120 444 59087
VCID: 204F8AB0F3C31C3E51-8074
3 Faults Found:
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 170762 km
Time Indication: 0
Date: 2016.01.29
Time: 06:48:41
Freeze Frame:
RPM: 2150 /min
Load: 58.0 %
Speed: 118.0 km/h
Temperature: 88.0°C
Temperature: -10.0°C
Absolute Pres.: 960.0 mbar
Voltage: 11.938 V
008224 - Intake Manifold Flap Position Sensor (Bank 2)
P2020 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 170762 km
Time Indication: 0
Date: 2016.01.29
Time: 06:48:41
Freeze Frame:
RPM: 2150 /min
Load: 58.0 %
Speed: 118.0 km/h
Temperature: 88.0°C
Voltage: 11.938 V
000406 - Engine Oil Temp. Sensor (G8)
P0196 - 004 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 170860 km
Time Indication: 0
Date: 2016.01.30
Time: 11:31:40
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 63.0°C
Absolute Pres.: 950.0 mbar
Voltage: 10.922 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 C HW: 09L 927 156 A
Component: AG6 09L 4,2lFSI USA 0010
Revision: --H01--- Serial number: 4188893
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 234585BCE2D507264C-8076
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0007597
Shop #: WSC 29532 000 00000
VCID: 224B80B8FDCF0E2E47-8076
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F4794727
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58BFE250EB1394FE69-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 4
Reset counter: 196
Mileage: 170848 km
Time Indication: 0
Date: 2016.01.30
Time: 11:11:34
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071648
Shop #: WSC 00000 785 00200
VCID: 244786A0E7DB001E35-8070
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 731 K HW: 4E0 035 729 A
Component: Interfacebox H43 2740
Revision: 00000000 Serial number: 348EV067503468
Coding: 0000003
VCID: 2959979480F9DD7606-807C
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH03 0040
Subsystem 2 - Serial number: 00000000010027
Subsystem 3 - Serial number: 0129.05.060000000100010084ÿ
Subsystem 4 - Serial number: 010084ÿ
1 Fault Found:
01327 - Control Module for Parking Aid (J446)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 210
Mileage: 171092 km
Time Indication: 0
Date: 2016.02.04
Time: 06:35:35
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 H
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000097413
Coding: 0037185
VCID: 1C37BE40DFAB38DE8D-8048
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO22052006065A000000000147ÿ†89
Subsystem 5 - Serial number: 000147ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO22052006065A00000000
Subsystem 7 - Serial number: 65A000000000134ÿ
1 Fault Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 8
Reset counter: 205
Mileage: 170757 km
Time Indication: 0
Date: 2016.01.29
Time: 06:45:54
Freeze Frame:
Temperature: -12.0°C
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H14 0230
Coding: 0143123
VCID: 36634CE84147828E9B-8062
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH12 0090
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8125959
Shop #: WSC 00000 000 00000
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7F5025602
VCID: 285F92909BF3E47E19-807C
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 157
Mileage: 170871 km
Time Indication: 0
Date: 2016.01.31
Time: 14:01:12
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Revision: 91H12400 Serial number: 0037Q00069X+
Coding: 0532707
Shop #: WSC 02120 444 83870
VCID: 26439CA891E7F20E2B-8072
Subsystem 1 - Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Subsystem 2 - Serial number: 368LT
Subsystem 3 - Serial number: 0001.01.0000H0100000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†63328RB401310B7BCÿ†63
Subsystem 5 - Serial number: 10B7BCÿ†63428RB401310B061ÿ†63
Subsystem 6 - Serial number: 10B061ÿ†63528RB401310B77Aÿ†63
Subsystem 7 - Serial number: 10B77Aÿ†63628RB401310AF3Eÿ†63
Subsystem 8 - Serial number: 10AF3Eÿ†63729RB4013844A6Jÿ†63
Subsystem 9 - Serial number: 844A6Jÿ†63829RB4013844A3Hÿ
Subsystem 10 - Serial number: 844A3Hÿ
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 B
Component: J0527 0410
Revision: 00H02000 Serial number: 90055061180014
Coding: 0012241
Component: E0221 H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 C HW: 4E0 920 951 C
Component: KOMBIINSTR. VDO H82 0520
Revision: D03 Serial number: AUDID3F4000156
Coding: 0032203
Shop #: WSC 29532 002 104857
VCID: 25419BA4ECE1F91622-8070
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B065048152
Coding: F5D5DF7F307A0E
VCID: 6CD7AE804F8B085EBD-8038
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
3 Faults Found:
01583 - Leak in System Detected
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 4
Reset counter: 211
Mileage: 170872 km
Time Indication: 0
Date: 2016.02.01
Time: 06:39:34
01772 - Signal from Level Control Pressure Sensor (G291)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 214
Mileage: 170926 km
Time Indication: 0
Date: 2016.02.01
Time: 16:09:15
01400 - Suspension Level Control
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 212
Mileage: 171203 km
Time Indication: 0
Date: 2016.02.05
Time: 06:36:12
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071658
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 C HW: 4E0 919 887 D
Component: MNS US H48 0960
Revision: 00000000 Serial number: 381EI067500065
Shop #: WSC 40329 444 53665
VCID: 2E536488B917BA4ED3-807A
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H04 0090
Serial number: 00000612800025
Coding: 0003477
VCID: 1D31B344C4B131D67A-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032364
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H07 0010
Revision: 00100007 Serial number: W040605190661
Coding: 0048766
VCID: 2A5B689885FFD66E0F-807E
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 F
Component: DSP-High D3 H02 0070
Revision: PROD_01 Serial number: 00000000000382
Coding: 0000026
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000086595
Coding: 0010111
VCID: 1E33B448C9B72ACE63-804A
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Subsystem 2 - Serial number: 0253440T152G05
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0100
Coding: 0032364
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000922
Shop #: WSC 05151 444 125825
VCID: 1F4D894CCEBD23C668-804A
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 M HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0570
Revision: 00000000 Serial number: 396E%067537928
Coding: 0000002
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000008951
Shop #: WSC 02120 444 52495
Subsystem 1 - Part No: 000 915 105 AK
Component: von JCB 4082104656
Coding: 303030393135313035414B4A434234303832313034363536
Shop #: WSC 29532 002 1048576
4 Faults Found:
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 170860 km
Time Indication: 0
Date: 2016.01.30
Time: 11:42:22
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 170860 km
Time Indication: 0
Date: 2016.01.30
Time: 11:42:32
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 170860 km
Time Indication: 0
Date: 2016.01.30
Time: 11:42:58
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 170869 km
Time Indication: 0
Date: 2016.01.30
Time: 14:53:40
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032364
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000900045681
Coding: 0232125
1 Fault Found:
01521 - Sensor for Tire Pressure
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 85
Reset counter: 0
Mileage: 170506 km
Time Indication: 0
Date: 2016.01.26
Time: 16:10:17
Freeze Frame:
(no units): 255.0
Temperature: -3.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000605160168
Shop #: WSC 12336 024 394758
VCID: 346776E0573B909EA5-8060
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J65101C
Coding: 1120503
VCID: 5CB7FE409F2B78DE4D-8008
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0030
Revision: 00H12000 Serial number: 08720613807027
Coding: 0221208
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 D HW: 4E0 862 335
Component: Handyvorb2 H13 0700
Revision: 00000000 Serial number: 00000007530691
Coding: 0010900
Ross-Tech: Home
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 170762 km
Time Indication: 0
Date: 2016.01.29
Time: 06:48:41
Freeze Frame:
RPM: 2150 /min
Load: 58.0 %
Speed: 118.0 km/h
Temperature: 88.0°C
Voltage: 11.938 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 170762 km
Time Indication: 0
Date: 2016.01.29
Time: 06:48:41
Freeze Frame:
RPM: 2150 /min
Load: 58.0 %
Speed: 118.0 km/h
Temperature: 88.0°C
Voltage: 11.938 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 170860 km
Time Indication: 0
Date: 2016.01.30
Time: 11:31:40
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 63.0°C
Voltage: 10.922 V
Coding: 0000002
Coding: 0007597
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 196
Mileage: 170848 km
Time Indication: 0
Date: 2016.01.30
Time: 11:11:34
Coding: 4071648
Coding: 0000003
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 210
Mileage: 171092 km
Time Indication: 0
Date: 2016.02.04
Time: 06:35:35
Coding: 0037185
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 205
Mileage: 170757 km
Time Indication: 0
Date: 2016.01.29
Time: 06:45:54
Freeze Frame:
Coding: 0143123
Coding: 00000036
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 157
Mileage: 170871 km
Time Indication: 0
Date: 2016.01.31
Time: 14:01:12
Coding: 0532707
Coding: 0012241
Coding: 0032203
Coding: 0015510
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 211
Mileage: 170872 km
Time Indication: 0
Date: 2016.02.01
Time: 06:39:34
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 214
Mileage: 170926 km
Time Indication: 0
Date: 2016.02.01
Time: 16:09:15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 212
Mileage: 171203 km
Time Indication: 0
Date: 2016.02.05
Time: 06:36:12
Coding: 4071658
Coding: 0003477
Coding: 0032364
Coding: 0048766
Coding: 0000026
Coding: 0010111
Coding: 0032364
Revision: A32C0220
Coding: 0000922
Coding: 0000018
Coding: 0000002
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 170860 km
Time Indication: 0
Date: 2016.01.30
Time: 11:42:22
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 170860 km
Time Indication: 0
Date: 2016.01.30
Time: 11:42:32
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 170860 km
Time Indication: 0
Date: 2016.01.30
Time: 11:42:58
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 170869 km
Time Indication: 0
Date: 2016.01.30
Time: 14:53:40
Coding: 0032364
Coding: 0232125
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 85
Reset counter: 0
Mileage: 170506 km
Time Indication: 0
Date: 2016.01.26
Time: 16:10:17
Freeze Frame:
(no units): 255.0
Temperature: -3.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 1120503
Coding: 0032364
Coding: 0221208
Coding: 0010900
Sounds like you have a leak to me, usually a strut. Did any one corner seem lower than the others? The compressor is not supposed run that long, definitely not a whole trip home. If your compressor isn't broken, it will be soon if that keeps up.
Corners do not seem to be low but I have not measured. I actually just received my compressor rebuild kit. I understand that after 2,5, and 10 hours the system comes out of sleep mode to adjust the height so I hope the pump doesn't keep running and burn out.
something i didn't mention was when I start the car it makes 5 or 6 soft ticking sounds about 2 seconds apart and then stops. (Just trying to relay all info I can.)
It's not running at all right now, but wonder if it will start when it comes out of sleep mode. Just checked and its been about 2 1/2 hours and not running.
When I get into my car and wait a few seconds (ignition off) , it will adjust the height using the air that is in the reservoir. I can hear the air valve click on and off as needed to accomplish this. Apparently it knows that I got into the car and is preparing the suspension for travel.
I did the rebuild service kit and it was great for about 6-8 months or so but then the compressor got loud and ran more frequently so I had to replace it. Couldn't find any leaks so i guess it just came to the end of it's life. Everything sweet now
I am going to replace the O and piston ring in the air compressor. I do have a pit in my garage so I don't need to jack it up but to get the left tire off. I am wondering about venting the system. The Bentley manual says "Vent System" and looks like this is done with VCDS. I was told by a wise man once that the manual is not always accurate. Should I block up both sides? Does anything special need to be done or just pull the supply line? What about the back? Will the accumulator maintain the rear height?
When I changed my compressor I just jacked it up, changed it and let it down. No need to vent anything. I think I had to remove the belly pan and front wheel well liner.
I had to remove the fuse as the pumpm will not stop running now. How long can one drive with the fuse out and pump not running. I would think it OK until the pump is replaced or is it bad for some reason?
