ami retro fit...how to split fiber optic cable ? - AudiWorld Forums
Old 05-17-2014, 07:24 PM   #1
Default ami retro fit...how to split fiber optic cable ?
I need to install an AMI in an A6 and I have the fiber optic cable that requires taking a plug apart to change fiber cables. I did my install so long ago I do not remember what to do with the plug, and I can not find anything with search to show me. Anyone know how ?
awdinut is offline   Reply With Quote
Old 05-17-2014, 09:35 PM   #2
You can't "split" the fiber cable. There is a Y adapter that comes with the kit, you install this between the changer and AMI module.
bmwm750 is offline   Reply With Quote
Old 05-17-2014, 09:46 PM   #3
mishar's Avatar
Will this help?
mishar is offline   Reply With Quote
Old 05-17-2014, 09:54 PM   #4
05SilverA8's Avatar
This may help also, same setup for doing the AMI:
05SilverA8 is offline   Reply With Quote
Old 05-17-2014, 09:59 PM   #5
Senior Member
MP4.2+6.0's Avatar
Default Y adapter is the electrical side..
for the power takeoff from the CD changer. On the optical, you extend the loop by taking one side of the optical ring away from the CD changer, essentially moving it to the "same" side of the AMI unit, and then adding the optical between the two. The wiring kit did include a fitting for the optical that did seem kind of like a "splitter," but light wise I believe it's as I describe and that piece was actually probably a coupling to enable the extension and the in-out serial connection nature of the optical loop.
MP4.2+6.0 is offline   Reply With Quote
Old 05-18-2014, 06:05 AM   #6
Default there is no 'y' adapter...
Quote:
there is a connector for connecting one line from the original CD cable and one line from the new AMI cable in a straight line loop. The other AMI fiber line has to go into the CD optic plug.
Old 05-18-2014, 06:10 AM   #7
Default thats a start...
Quote:
Originally Posted by mishar View Post
Will this help?
Thanks. But as I recall , the plug was difficult to take apart and get together, but I need a text telling me the steps...those two photos dont bring to mind what it is that is required. Sorry.
Old 05-18-2014, 06:21 AM   #8
Default thats part of the puzzle
Quote:
Thankyou, shows me which half of the CD plug to 'loop'.
Old 05-18-2014, 08:07 AM   #9
05SilverA8's Avatar
if you need detailed pictures of the connectors PM me and I will forward you some if you can't figure out how to get them apart.
Old 05-18-2014, 08:15 AM   #10
mishar's Avatar
1. Picture:
Release locking latch in fiber optic cable connector (arrow).
2. Picture:
Release secondary latch (6) using a small screwdriver (arrow).
Release catch (2) and remove fiber optic cable (5) with brass connector pin (4) from base module (1).
Thread Thread Starter Forum Replies Last Post
Who has Carista App for their B8? Chigger S4 (B8 Platform) Discussion 11 10-07-2015 03:03 PM
CARBON FIBER HOOD? DanfZX14 A6 (C7 Platform) Discussion 6 09-29-2015 11:18 AM
VAG-com question (older serial port type) mxp A4 (B6 Platform) Discussion 0 09-28-2015 02:04 PM
Removal of Start Button housing help? RNtoNP A8 / S8 (D3 Platform) Discussion 6 09-28-2015 09:04 AM
2004 Audi A8 Bluetooth Help... Singh15 A8 / S8 (D3 Platform) Discussion 9 09-27-2015 10:55 AM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
