Sponsored by:
Sponsored by:
Antenna; Passenger Side (R135)
Old 01-26-2015, 09:54 PM
DA8
DA8's Avatar
Default Antenna; Passenger Side (R135)
I get these codes regularly. I do have issues sometimes with the remote not connecting. It manifest by the push start not working saying "No Key" on the driver's center display and on the right (passenger) door when I try to open it sometimes I have to pull the handle a few times before my presence is recognized.
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Control Module Part Number: 4E0 910 131 HW: 4E0 909 131 D
Component and/or Version: FBS AUDID3 H04 0140
Software Coding: 0410624
Work Shop Code: WSC 02311 785 00200
Additional Info: XXXXXXXXXXX ELV XXXX
Additional Info: Geraet 00200
VCID: 58B59F5BEBC7CFE177B-800D
1 Fault Found:
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 0
Reset counter: 84
Mileage: 212304 km
Time Indication: 0
Date: 2015.01.26
Time: 19:31:16
Address 25: Immobilizer Labels: 4E0-910-131.lbl
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 21
Mileage: 209232 km
Time Indication: 0
Date: 2014.12.24
Time: 21:24:34
Curious on opinions. Is this as simple as replacing the R135 antenna?
Old 01-26-2015, 10:50 PM
mishar's Avatar
If it is intermittent it may be contact too. 2004/05's are known for not perfect harnesses. When you catch it not working try touching rear door handle to check if that one is working.
Also try unlocking and locking again with the remote. That helped when my old key was acting up.
am_ver
04-22-2015 03:15 PM
fe342185
10-17-2014 12:54 PM
stevolaad
05-23-2013 08:35 AM
Daniel Blackhurst
VAG-COM Discussion
04-22-2013 06:18 AM
EuroCK
Audi A3 / S3 / RS 3
09-25-2008 01:33 PM
Quick Reply: Antenna; Passenger Side (R135)
