Anyone here got a Bluetooth OBD adapter?
'Sup guys,
We're developing an Android app for Audi diagnostics and customization/coding: Carista. We need more people with A8s to test our latest beta version, which adds lots of new customization options for the D3 (and many other VAG models too). The app allows you to configure lots of cool things on your D3, as well as do VAG-specific diagnostics of all modules in the car. Check out the links in my signature.
All you need is an ELM327 bluetooth OBD adapter (which costs about $10 on Amazon) and an Android phone or tablet.
Over the next week, whoever sends me a "debug data report" (see below) from an A8 or S8 will get a free trial of the paid features in the app.
So:
Step 1: Get the beta from here: Beta-Testing | Carista OBD2 - Vehicle Diagnostics and Customization
Step 2: Send a debug data report from within the app: "Debug menu" -> "Collect debug data" (more detailed instructions at the bottom of the beta page)
So:
Yes, certainly, but it's gonna be time-limited, that's just how it works with Google Play in-app purchases: Google automatically cancels "test purchases" after 14 days. There's no other way to give out paid functionality for free. But yeah, during those 14 days, you can configure everything the way you want it and just leave it that way and never buy the app with real money. No pressure
I also got one to use with torque software...
If that's the one works with your software then send me your software, I'll test with my beater A6, until I know your software doesn't program something that I don't want then I'll try it on my A8 and Q7.
Cheers,
Louis
Cheers,
Louis
Tested with Galaxy S3 10" tablet and both of these adapters:
http://www.totalcardiagnostics.com/i...luetooth-1.jpg
http://www.iobd2.org/wp-content/uplo..._3509032_a.jpg
Pros:
Easy to use and install (compared to VCDS, VAS)
Has some good features (headlight programming, instrument cluster language, door locks... can BTW in the A8.etc be programmed via MMI, so totally useless feature to us )
Relatively inexpensive for it's functionality
CONS
It doesn't have any useful realtime data functionality (wheel speeds for ABS, engine data... like VCDS, VAS) to diagnose ABS, ECU, TCU, SRS etc problems, or has it?
Seemed to work well in general, except on my A8L W12 2008, it could only diagnose:
ECU (not with the upper adapter)Drivers door module
Instrument cluster
Comfort control module.
Parking brake
Driver's door module
On Volvo S90 -98 it was only able to diagnose
ECU
A setback was, that it was not able to diagnose ABS, airbags etc on either vehicle.
The A8 has about 40 control units that i don't care to list here, and the S90 has:
ECU, TCU, ABS, ECC, SRS, Cruise, elecric seats (2), Alarm, and it was able to diagnose none of these.
Pros:
CONS
Instrument cluster
Parking brake
ECU
'Sup guys,
So:
So:
Oh, and if the beater A6 you're referring to is the '96 in your signature, it won't work. The app is only compatible 2005+ A6s (and in general, VAG cars that use the CAN protocol). See Supported Vehicles | Carista OBD2 - Vehicle Diagnostics and Customization
Pros:
CONS
Instrument cluster
Parking brake
ECU
Pros:
CONS
Instrument cluster
Parking brake
ECU
So to clarify about the diagnostics:
For your A8: all control units should be supported. Carista displays a list of fault codes ONLY from the control units that HAVE fault codes. But that doesn't mean it doesn't support the others. Or do you know that some other module in your car has errors, but was not displayed in Carista?
For your Volvo: Carista does not support any Volvo-specific diagnostics and for that reason, it's only able to diagnose the drivetrain control units via the standard OBD2 protocol, just like the many OBD2 apps out there. That means the engine and transmission ECUs. Again, it will only show you errors as "OBD2" errors without specifying which module they came from.
If you're not using the beta, please get the beta. And then send me a debug data report from the slide-out menu -> "Debug menu" -> "Collect debug data". Thanks very much.
Are you working with, or are you part of Ross-Tech? If not, you need to. If someone buys something from you and it turns out that even one little thing does not work, buyers will be calling Ross Tech for help and they will say something to the effect of "sorry, not our product, untested, not approved. If it don't work, it don't work.
