Anyone with problems with windows roll down / mirror position?
I have two problems that are starting to bother me more.
first, I coded the windows for remote opening and closing, and months after they worked, they no longer do.
My second frustration is often when opening my door, the driver side mirror aims up OR down even though no one else has used my car (I am the only driver).
TIA!
TIA!
TIA!
TIA!
On second one, maybe it has the settings from a different key than you think saved in the position memory. Try re saving the positions for the key you are using. After that, and especially if movement is randomly up or down, that's hard t figure out. On mine the passenger side dip function when reversing seemed to get balky and I finally changed the mirror motor, which seemed to help. The motor is kind of pricy though if you can't diagnose fairly specifically.
Yes, it is randomly up or down. I am not sure how it counts, but i am either thinking of taking it apart and cleaning the insides, or swapping the mirror. I just did not want to do either if it is being "counted" from something inside the door/car.
Thanks, I will try the battery too. The "remote entry" still works many months after the windows control does not, so I thought otherwise.
Tsunami
Q5/SQ5 MKII Discussion
05-03-2019 09:32 PM
raj99
08-24-2018 03:43 AM
detailersdomain
06-15-2004 05:16 PM
klerk
03-05-2004 09:44 PM
