Sponsored by:
Sponsored by:
AUDI A8 D3 4.2 V8 BFM. CAR SWITCHED OFF WHILE DRIVING .
Old 05-27-2014, 01:07 PM
  #11
03_AR_CO's Avatar
Originally Posted by aTOMic*
I thought THIS was the funny stuff...
If I pulled a plug and it looked like that I'd be in caps lock, too!
Good luck, altaf.
-Tom
Yup, nothing funny about the look of that plug, never seen anything quite like it, hopefully never will ....... hope there is a good outcome for the OP
Old 05-27-2014, 08:44 PM
  #12
MP4.2+6.0's Avatar
Default I saw it once...not pretty
when my dad had me pull him home the old fashioned way--with a rope. He said the 225 slant 6 in the Dodge just "gradually lost power." Motor turned but would't run. Pulled the plugs and found one melted down like that. Ran a compression check and got zero on same cylinder. Pulled head and found piston blown completely through to where I could literally see down to the rod bearing area of the crank, plus the wrist pin still hanging on to the remnants of the piston.
Yeah right, just gradually lost power dad?
Old 05-28-2014, 05:36 PM
  #13
Panelhead's Avatar
Default Saw an engine like that
Saw a 327 Chevy that melted the electrodes. I think the timing was advanced too far and it was detonating.
Fresh plugs got it running. Just not very well or for very long. About that time a others friends Vega GT warped the head, the block, and threw a rod. The spark plugs looked better than this one. Overheating killed it also.
Old 05-28-2014, 07:25 PM
  #14
jakematic's Avatar
Well I for one hope he comes back to tell us the results.
It's like when you tape Svengoolie on your BetaMax and it cuts off before the end...
Old 06-01-2014, 11:41 PM
  #15
altaf's Avatar
Hi guys. This is what was found in clyinder #1.
Still busy with it .
Will keep you guys updated.
Old 06-02-2014, 06:53 AM
  #16
MP4.2+6.0's Avatar
Default Bent valves obviously; timing belt...
You said in a prior post timing belt was good. I really doubt that; also look at tensioner, water pump and other pulleys etc. If belt still doesn't show issues, then it would probably be down to a thrown rod or broken piston specific to that cylinder.
In any case, at least the head needs to be pulled and valves replaced if head itself undamaged. But more likely, a motor rebuild alongside a decent guess that more valves will be bent, and on both sides. The most cost effective could well be a used engine swap--with a full belt job going in.
Old 06-02-2014, 02:10 PM
  #17
AudiWorld Wiseguy
dvs_dave's Avatar
Ouch. Given that the plug is crushed as well as the bent valves indicates that the piston is no longer attached to the crank. Broken timing gear will bend valves but plug (snigger) should remain intact. My bet is on failed big end bolts or a snapped con-rod.
The engine must be making a terrible racket when cranking?
Old 06-03-2014, 07:44 AM
  #18
mishar's Avatar
If only that cylinder valves are bent it is not timing belt. It is most likely that something got into cylinder. Piston is broken for sure. It sounds like engine replacement.
Roma is nice.
Old 09-21-2014, 11:54 AM
  #19
altaf's Avatar
Old 09-21-2014, 11:55 AM
  #20
altaf's Avatar
complete engine overall
AE pistons
Quick Reply: AUDI A8 D3 4.2 V8 BFM. CAR SWITCHED OFF WHILE DRIVING .
