Audi A8 D3 MMI 2G Custom Entertainment System
#21
AudiWorld Wiseguy
Those ones will do the dynamic lines, but not the park sensor graphic also like the OEM RVC implementation. How is that achieved? Presumably by that custom prototype interface?
#22
As long as you have CAN Bus connected and the 4E0 919 283 C
for back up line, you need MMI version 41xx and up (when RVC starts in 2007)
When you select back up camera function through CAN BUS, the lines and graphical can be selected individually or combo together.
These are things I understood the MMI RVC back up camera when I retrofit my car.
Cheers,
Louis
#23
Engineer
Non of those interface will do the dynamic lines or park sensor graphic, they don't have these wires and the require a reverse signal wire
their software is from 2009 the one I'm using is December 2015 software, a friend of mines has the one in the link in this car for a while it just show the regular straight lines like aftermarket camera he will be changing to one of these this week
to answer dave question before last
lol its not really weird, I wanted reverse camera and didn't want to got through all the FBAS this and that.... so I went researching and had it made from one of the normal ones around.
so I get all the oem options like doing FBAS mod with more features and less headache, no coding no component protection, its only 5 wires to connect, the hard work is ripping the dash apart but its made in such a way you don't need to hack or cut any wired in the car (I hate cutting car wires) it just connects to car already vacant molex connections... I know these cars are old but still quiet a few in circulation... so its not weird just like how I have Bluetooth Streaming AUX, also I'm trying to hack the MMI pad to usb or serial to control a pi or android box but I dunno yet, I already know the MMI use Rotary encoders and what not but I'm trying to decode the final signals probably would not work...
but dave are you trying to get backup camera or just curious?
#24
AudiWorld Wiseguy
I'm both curious and toying with fitting a backup cam. I like the OEM implementation and would aim for that, but like you am not inclined to spend $$$$ replacing a bunch of perfectly good modules and messing around with component protection to do it.
#25
Whatever he got... Get it when it's available
Sounds really good, especially it actually works.
#26
Engineer
At their moment my mmi screen is out because I'm getting some information from it trying to make it higher resolution lol, probably install a touch panel I have while I'm at it, to control a pi or something, friend of mines wants the dvd player i have when i get him the module, i dont really use dvd and I can just
#27
I noticed you have the BOYO ATSC M/H MHC TV tuner.... did you get it to work? I got the BOYO VT-MHS Mobile TV Tuner + antenna and had to return it cos it didn't receive any stations (while mobile or stationary).
#28
Engineer
BOYO ATSC M/H MHC TV tuner works like a champ hard to find, discontinued. BOYO VT-MHS Mobile TV Tuner is ****, doesn't work..... I had mines 4 years now in my A6 but it had a problem with the internal power supply that got worst, would only stay on for 5 to 10 mins, so I replaced the tuner with a standard stationary one, useful if you just chilling in the car, in motion I use music videos, movies and tv shows, mostly music videos, they then to be less distracting that movies and tv shows.. but to answer you question use a standard tuner scan it stationary then you're good, there is only 1 channel in NY that mobile anyways... until I fix my boyo or find a better hybrid, ill stick to the stationary one..
#29
Ah, that explains it. Thanks.
