audi A8l 2008 MMI not working
my battery recently died, and i couldn't recharge and start the car at all my friend mistakingly put the - cable on the + rod and it sparked, now after the battery changed and all the screen wont turn up at all not manually or by the button
and all the button lights for the radio nav media they all dont work
what can i do to fix this?
Sounds like you lost the big fuse. It's something like 60amps or the like. It's in the trunk by the battery and doesn't look like the regular fuses. It's an effort to protect those systems from just such an occurrence, but it doesn't always. Good luck!
It's just my first thought of what to check first. Check all your other fuses while your at it it. Then if you've still not fixed it, get a VCDS scan. It gets very hard to diagnose beyond that without a scan.
+ 1 on check that heavy fuse in back. Body shop did something similar to mine during one repair and all was dead MMI and console wise until replaced.
i checked all fuses on the passenger side and behind the fire extinguisher
and also the back side in the navigation box
turns out 4 fuses were burnt after i replaced them everything was all good
thanks for everything
