Audi S8 d3 2007 Need help with error messages
Hi, please if someone could help me with the fault codes. The most worring is the Engine II codes that came after i opened and cleaned the sparkplugs, The missfire has now disapperad but the cam exhasut is still there. What is "004192 - Bank2; Exhaust Cam Adjustment Circuit
P1060 - 004 - Open Circuit" mean?
And help on other faultcodes would be good.
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: OK 0000
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
1D-Driver Ident. -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 K HW: 09E 927 156 B
Component: AG6 09E 5,2 FSI RdW 0010
Revision: --H01--- Serial number: 0086220
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 2B5377EE8A725A461EF-807E
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 D HW: 4E0 614 517 AB
Component: ESP 5.7 allrad H46 0500
Coding: 0001627
Shop #: WSC 27553 000 00000
VCID: 24419CD2E7AC953EDF5-8071
1 Fault Found:
00003 - Control Module
014 - Defective
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F4395243
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: D8B978226B6481DE03D-808D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 4
Fault Frequency: 0
Reset counter: 191
Mileage: 159856 km
Time Indication: 0
Date: 2015.03.08
Time: 17:16:52
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 731 G HW: 4E0 035 729 A
Component: Interfacebox H43 2830
Revision: 00000000 Serial number: 300FN067568442
Coding: 0000001
VCID: 254781D6EC966C36C8B-8070
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH03 0040
Subsystem 2 - Serial number: 00000000010484
Subsystem 3 - Serial number: 0101.06.060000000100010059ÿ
Subsystem 4 - Serial number: 010059ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000098379
Coding: 0041067
VCID: 1C31A432DFDCADFE675-8049
1 Fault Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 190
Mileage: 159395 km
Time Indication: 0
Date: 2015.03.03
Time: 00:21:10
Freeze Frame:
Temperature: 14.0°C
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H14 0230
Coding: 0133121
VCID: 3665569A413017AE711-8063
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00141886
Shop #: WSC 02313
1 Fault Found:
00908 - Control Module for Wiper Motor
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 2
Reset counter: 227
Mileage: 0 km
Time Indication: 0
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276U7300340
Coding: 0000001
Address 11: Engine II Labels: Redir Fail!
Part No SW: 4E0 910 552 HW: 4E0 907 552
Component: 5.2L V10/4V FSI ª0060
Revision: 5AH11--- Serial number: AUX3Z0F4395243
Coding: 01060003190F0260
Shop #: WSC 43851 123 85412
VCID: DFCB533E0E4A76E6427-808A
6 Faults Found:
012850 - Oxygen (Lambda) Sensor B4 S1; Heating Circuit
P3232 - 004 - Open - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 159350 km
Time Indication: 0
Date: 2015.03.03
Time: 13:20:16
Freeze Frame:
RPM: 636 /min
Load: 23.5 %
Speed: 45.0 km/h
Temperature: 93.0°C
Temperature: 26.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
049717 - No Communications with Cruise Control (Front) Distance Sensor
U0235 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 159350 km
Time Indication: 0
Date: 2015.03.03
Time: 13:45:15
Freeze Frame:
RPM: 646 /min
Load: 23.1 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 48.0°C
Voltage: 13.462 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 159869 km
Time Indication: 0
Date: 2015.03.08
Time: 17:00:30
Freeze Frame:
RPM: 736 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 39.0°C
Temperature: 17.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.589 V
000773 - Cylinder 5
P0305 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 159869 km
Time Indication: 0
Date: 2015.03.08
Time: 17:00:30
Freeze Frame:
RPM: 736 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 39.0°C
Temperature: 17.0°C
Voltage: 13.589 V
P1060 - 004 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 159869 km
Time Indication: 0
Date: 2015.03.08
Time: 17:18:09
Freeze Frame:
RPM: 635 /min
Load: 24.3 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 30.0°C
Voltage: 13.970 V
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4E0 910 561 F HW: 4E0 907 561 F
Component: ABSTANDSREGELUNGH03 0020
Coding: 0041164
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10111101
Fault Priority: 5
Fault Frequency: 2
Reset counter: 227
Mileage: 159356 km
Time Indication: 0
Date: 2015.03.03
Time: 00:00:00
Freeze Frame:
Temperature: 7.0°C
Voltage: 11.26 V
Bin. Bits: 00000000
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 D HW: 4E0 959 655 H
Component: Airbag 9.41 H13 3710
Revision: 91H13371 Serial number: 0037P000KY25
Coding: 0431707
VCID: 275B8BDE969A7E26FA7-8072
Subsystem 1 - Serial number: 63328RB4014C93E9U
Subsystem 2 - Serial number: 63428RB4014C936AO
Subsystem 3 - Serial number: 63528RB4014C9179N
Subsystem 4 - Serial number: 63628RB4014C932FR
Subsystem 5 - Serial number: 63729RB404CDB04E+
Subsystem 6 - Serial number: 63829RB40148FA8F2
Address 16: Steering wheel Labels: None
VCID: 55A7F116BC763CB698B-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 931 N HW: 4E0 920 931 N
Component: KOMBIINSTR. VDO H82 0520
Revision: D03 Serial number: AUDID3F5000207
Coding: 0032013
Shop #: WSC 80093 222 69422
VCID: 2E557EFAB9602F6E391-807B
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 265 081 N
Component: Heizgeraet H07 0110
Revision: 0000000C Serial number: 00000009006406
Coding: 0000111
Shop #: WSC 00000 000 00000
VCID: 1A3DA22AD5E8D3CE759-804F
2 Faults Found:
01406 - No Flame
000 - -
01415 - Recirculating Pump (V55)
010 - Open or Short to Plus - Intermittent
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4E0 907 468 G
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0100J0640380C4
Coding: F5D9DFFF517E1E
VCID: ECD134F2CFFC1D7ED75-80B9
Address 1D: Driver Ident. Labels: 4E0-910-218.lbl
Part No SW: 4E0 910 218 A HW: 4E1 905 218 B
Component: FPI_1 H01 0010
Revision: 01000101 Serial number: 01062006205859
VCID: 1F4B933ECECAB6E6827-804A
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8132620
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
VCID: 2A5D72EA8588434EE59-807F
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4063342
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 Q HW: 4E0 919 887 D
Component: MNS ECE H48 0850
Revision: 00000000 Serial number: 364EX067566184
Shop #: WSC 27553 123 61807
VCID: 3B7347AE7A12CAC68EF-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H04 0090
Serial number: 00000615100160
VCID: 1D37A936C4C6A4F690B-8048
No Faults Found
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032621
VCID: 204990C2F3B4891EBBD-8075
2 Faults Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 14
Reset counter: 230
Mileage: 156976 km
Time Indication: 0
Date: 2015.01.30
Time: 19:43:26
02110 - Window Regulator Switch
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 204
Mileage: 157856 km
Time Indication: 0
Date: 2015.02.08
Time: 00:49:52
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H07 0010
Revision: 00100007 Serial number: W040606100058
Coding: 0004728
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
Address 47: Sound System Labels: None
Part No SW: 4E0 910 466 A HW: 4E0 035 466
Component: BO_D3 H06 0170
Revision: 12S00002 Serial number: 02905060003088
Coding: 0000026
Subsystem 1 - Part No: 4E0 910 465 A
Component: BO_D3_SLAVE H31 0100
Subsystem 2 - Serial number: 01403060001066
Subsystem 3 - Serial number: 0214.03.060000000100030005ÿ
Subsystem 4 - Serial number: 030005ÿ
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 B
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000000353
Coding: 0010111
VCID: 1E35AE3AC9C0BFEE891-804B
Subsystem 1 - Part No: 4E0 910 511
Component: UGDO HL ECE H06 0050
Subsystem 2 - Serial number: 0253439TJ7XQ06
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0100
Coding: 0032621
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000018
Shop #: WSC 40350 222 123066
VCID: 295F8DE6808E4856EC3-807C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: NOSUBSYSTEM
Component: AFS-Modul rechts
1 Fault Found:
02234 - Right Headlight Power Output Stage (J668)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 191
Mileage: 159864 km
Time Indication: 0
Date: 2015.03.08
Time: 17:10:55
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 M HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0570
Revision: 00000000 Serial number: 396F0067538693
Coding: 0000001
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 A HW: 4E0 919 148
Component: R0078 TVhybridTuner 0280
Revision: R0H05000 Serial number: 76300700337902
Coding: 0000001
VCID: 214F95C6F8BE8016B43-8074
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000009655
Shop #: WSC 27553 123 57267
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2803312772
Coding: 344530393135313035412056413032383033333132373732
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032621
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 R HW: 4E0 035 753 A
Component: SDS 3500 DE H45 0630
Revision: 00000000 Serial number: 00000605170163
Shop #: WSC 12336 024 394758
VCID: 356751965C361CB678B-8060
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J6510VU
Coding: 1021302
VCID: DCB164321F5C6DFE275-8089
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0032621
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0030
Revision: 00H12000 Serial number: 08720615707686
Coding: 0321008
VCID: 23439FCEE2A29206A6F-8076
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H00 0700
Revision: 00000000 Serial number: 00000000000000
Coding: 0000000
2 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 135
Mileage: 84983 km
Time Indication: 0
Date: 2010.10.02
Time: 09:19:25
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 168
Mileage: 70635 km
Time Indication: 0
Date: 2009.12.06
Time: 22:52:10
End ---------------------------------------------------------------------
Coding: 0000001
Coding: 0001627
1 Fault Found:
014 - Defective
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 191
Mileage: 159856 km
Time Indication: 0
Date: 2015.03.08
Time: 17:16:52
Coding: 4063328
Coding: 0000001
Coding: 0041067
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 190
Mileage: 159395 km
Time Indication: 0
Date: 2015.03.03
Time: 00:21:10
Freeze Frame:
Temperature: 14.0°C
Coding: 0133121
Coding: 00000036
Shop #: WSC 02313
Coding: 00141886
Shop #: WSC 02313
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 227
Mileage: 0 km
Time Indication: 0
Coding: 0000001
6 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 159350 km
Time Indication: 0
Date: 2015.03.03
Time: 13:20:16
Freeze Frame:
RPM: 636 /min
Load: 23.5 %
Speed: 45.0 km/h
Temperature: 93.0°C
Temperature: 26.0°C
Voltage: 13.716 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 159350 km
Time Indication: 0
Date: 2015.03.03
Time: 13:45:15
Freeze Frame:
RPM: 646 /min
Load: 23.1 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 48.0°C
Voltage: 13.462 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 159869 km
Time Indication: 0
Date: 2015.03.08
Time: 17:00:30
Freeze Frame:
RPM: 736 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 39.0°C
Temperature: 17.0°C
Voltage: 13.589 V
000773 - Cylinder 5
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 159869 km
Time Indication: 0
Date: 2015.03.08
Time: 17:00:30
Freeze Frame:
RPM: 736 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 39.0°C
Temperature: 17.0°C
Voltage: 13.589 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 159869 km
Time Indication: 0
Date: 2015.03.08
Time: 17:18:09
Freeze Frame:
RPM: 635 /min
Load: 24.3 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 30.0°C
Voltage: 13.970 V
Coding: 0041164
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 227
Mileage: 159356 km
Time Indication: 0
Date: 2015.03.03
Time: 00:00:00
Freeze Frame:
Temperature: 7.0°C
Voltage: 11.26 V
Bin. Bits: 00000000
Coding: 0431707
No Faults Found
Coding: 0032013
Coding: 0000111
2 Faults Found:
01406 - No Flame
000 - -
Coding: 0015510
Coding: 4063342
No Faults Found
Coding: 0032621
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 230
Mileage: 156976 km
Time Indication: 0
Date: 2015.01.30
Time: 19:43:26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 204
Mileage: 157856 km
Time Indication: 0
Date: 2015.02.08
Time: 00:49:52
Coding: 0004728
Coding: 0000026
Coding: 0010111
Coding: 0032621
Coding: 0000018
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 191
Mileage: 159864 km
Time Indication: 0
Date: 2015.03.08
Time: 17:10:55
Coding: 0000001
Coding: 0000001
Coding: 0032621
Coding: 1021302
Coding: 0032621
Coding: 0321008
Coding: 0000000
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 135
Mileage: 84983 km
Time Indication: 0
Date: 2010.10.02
Time: 09:19:25
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 168
Mileage: 70635 km
Time Indication: 0
Date: 2009.12.06
Time: 22:52:10
Adress 11 Engine II
000768 - Random/Multiple Cylinder Misfire Detected P0300 - 001
000773 - Cylinder 5 P0305 - 001 - Misfire Detected
Solution - I cut the connector for Cylinder 5, Replaced it with a new Connector PartNo.1J0998724 and no more misfire.
Think of Cut the connector wire so close to the old connector as possible, so not much wire is cut of. Think of that the connector are numberd 1 2 3 4 for colour, connect right, check again before connecting. If you connect wrong, check FUSE I think nr30 i think, 30A Spoil fuse. DONT THROW THE OLD CONNECTOR, KEEP IT TO KNOW THE WIRING NUMBERS IF PROBLEM WOULD COME IN FUTURE.
How to. remove Airfilter about 4-5 screws, take out the connector, and 2 connector on the big air tube. remove. Skrew the skrews holding the connector, remove the connector from coil. open the casing holding the connectors, cut. FIX and put back everything, start
SOLVED
SOLVED
My latest Scan after some fixes. If anyone could help me with the rest i will be very thankful
07-Control Head -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
57-TV Tuner -- Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
2 Faults Found:
001072 - Catalyst System; Bank 2
P0430 - 002 - Efficiency Below Threshold
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 162449 km
Time Indication: 0
Date: 2015.03.26
Time: 22:06:05
Freeze Frame:
RPM: 1401 /min
Load: 22.0 %
Speed: 62.0 km/h
Temperature: 87.0°C
Temperature: 11.0°C
Voltage: 13.716 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 162470 km
Time Indication: 0
Date: 2015.03.26
Time: 23:08:06
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 88.0°C
Temperature: 19.0°C
Voltage: 12.192 V
Readiness: 0000 1001
Coding: 0000001
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 0
Reset counter: 218
Mileage: 162432 km
Time Indication: 0
Date: 2015.03.26
Time: 21:40:46
Coding: 4063328
Coding: 0000001
1 Fault Found:
01327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 3
Mileage: 162454 km
Time Indication: 0
Date: 2015.03.26
Time: 22:12:53
Coding: 0041067
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 218
Mileage: 162437 km
Time Indication: 0
Date: 2015.03.26
Time: 21:44:41
Freeze Frame:
Temperature: 9.0°C
Coding: 0133121
Coding: 00000036
Shop #: WSC 02313
Coding: 00141886
Shop #: WSC 02313
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 162433 km
Time Indication: 0
Date: 2015.03.26
Time: 21:35:31
Freeze Frame:
RPM: 570 /min
Load: 24.7 %
Speed: 0.0 km/h
Temperature: 106.0°C
Temperature: 28.0°C
Voltage: 13.208 V
Coding: 0041164
Coding: 0431707
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H14 0040
Coding: 0012151
VCID: E5C741D62C162C3688B-80B0
Component: Lenkradmodul H07 0090
Coding: 0032013
Coding: 0015510
Coding: 4063342
No Faults Found
Coding: 0032621
Coding: 0004728
Coding: 0000026
Coding: 0010111
Coding: 0032621
Coding: 0000018
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 218
Mileage: 162440 km
Time Indication: 0
Date: 2015.03.26
Time: 21:33:19
Coding: 0000001
Coding: 0000001
1 Fault Found:
02283 - Video Connection to Output [End Unit]
Freeze Frame:
Fault Status: 00101010
Fault Priority: 5
Fault Frequency: 3
Reset counter: 2
Mileage: 162454 km
Time Indication: 0
Date: 2015.03.26
Time: 22:14:09
Coding: 0032621
Coding: 1021302
Coding: 0032621
Coding: 0321008
Coding: 0000000
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 135
Mileage: 84983 km
Time Indication: 0
Date: 2010.10.02
Time: 09:19:25
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 168
Mileage: 70635 km
Time Indication: 0
Date: 2009.12.06
Time: 22:52:10
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 162449 km
Time Indication: 0
Date: 2015.03.26
Time: 22:06:05
Freeze Frame:
RPM: 1401 /min
Load: 22.0 %
Speed: 62.0 km/h
Temperature: 87.0°C
Temperature: 11.0°C
Voltage: 13.716 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 162470 km
Time Indication: 0
Date: 2015.03.26
Time: 23:08:06
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 88.0°C
Temperature: 19.0°C
Voltage: 12.192 V
Coding: 0000001
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 218
Mileage: 162432 km
Time Indication: 0
Date: 2015.03.26
Time: 21:40:46
Coding: 4063328
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 3
Mileage: 162454 km
Time Indication: 0
Date: 2015.03.26
Time: 22:12:53
Coding: 0041067
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 218
Mileage: 162437 km
Time Indication: 0
Date: 2015.03.26
Time: 21:44:41
Freeze Frame:
Temperature: 9.0°C
Coding: 0133121
Coding: 00000036
Shop #: WSC 02313
Coding: 00141886
Shop #: WSC 02313
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 162433 km
Time Indication: 0
Date: 2015.03.26
Time: 21:35:31
Freeze Frame:
RPM: 570 /min
Load: 24.7 %
Speed: 0.0 km/h
Temperature: 28.0°C
Voltage: 13.208 V
Coding: 0041164
Coding: 0431707
Coding: 0012151
Coding: 0032013
Coding: 0015510
Coding: 4063342
No Faults Found
Coding: 0032621
Coding: 0004728
Coding: 0000026
Coding: 0010111
Coding: 0032621
Coding: 0000018
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 218
Mileage: 162440 km
Time Indication: 0
Date: 2015.03.26
Time: 21:33:19
Coding: 0000001
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 2
Mileage: 162454 km
Time Indication: 0
Date: 2015.03.26
Time: 22:14:09
Coding: 0032621
Coding: 1021302
Coding: 0032621
Coding: 0321008
Coding: 0000000
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 135
Mileage: 84983 km
Time Indication: 0
Date: 2010.10.02
Time: 09:19:25
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 168
Mileage: 70635 km
Time Indication: 0
Date: 2009.12.06
Time: 22:52:10
@udi4.qwick
VAG-COM Discussion
08-15-2011 03:27 PM
