Auxiliary Fuse block install (w/ Blue Sea Systems Fuse block)
Having recently completed this upgrade in my C6, I decided to do same for the D3 this weekend. So far, I like the way it has turned out - same concept but slightly different configuration (at least for now).
First off, the obligatory disclaimer:
You assume sole responsibility for any any damage to your vehicle (or injury to self) if you follow this modification. Do your due diligence to understand the requirements + skills needed. As usual, disconnect the negative terminal of your battery BEFORE performing any electrical work on your car.
Parts List:
1 - Blue Sea Systems Fuse Block
1 - Blue Sea 100amp Circuit Breaker
5 - Bosch-style 30/40 Automotive relay
11 - M4 .7mm hex nut
3 - 4MM-.7x12mm cap screw (for relays)
25 - 5MM flat washers
11 - M4x20mm 3mm Hex Cap Screws
15' - 4AWG battery cable red and black each
Lot - 4 gauge, 10 gauge copper terminal connectors
Power distribution busbar
Cordless Drill
Mock-up:
I started out by making rough outline of how I wanted the fuse block + circuit breaker to be laid out. Given the placement of the battery and the lack of space in that right compartment, I chose to place the block within the trunk, making both easily accessibly both for adding accessories and to use the 'kill switch'.
Measure once, cut twice..
... I still managed to get the alignment way off...
4AWG Ground wire connected (to battery main negative cable).
Current Configuration:
This is how it looks at the moment. I thought of routing the cables through the blades of the vent; also considered drilling a 1.25" opening (with hole saw) for a grommet to route the cables through to the battery compartment. I will work on that next weekend.
With the circuit breaker (which also protects the fuse block), I can cut off power at any time. In the coming days I will be connecting a couple accessories (trunk LED, BlackVue 6502ch, Ham radio, Android TV box) to the the new fuse block.
Future updates:
1. Set up some of the circuits as switched using relays.
2. Modify the plastic/side vent cover so it has grommets to allow for easier routing of the cables.
Parts List:
Cordless Drill
Mock-up:
Future updates:
I did some minor updates today, installed a grommet to route the cables.
I also installed an LED strip (replacing the left trunk bulb); will switch out the one on the right to complete the look.
Last thing I did was install a tripple-function panel (USB charger, 12V outlet and Voltmeter). They all have their own (fused) circuits.
The USB charger is powered off the auxilliary fuse block, the Voltmeter is on the main busline left compartment (fed from the right compartment). The 12V outlet will go on the fuse block as well.
Just curious...instead of making your A8 look like the Back To The Future De Lorian why not install on the underside of the hat shelf where it wouldnt be seen and the cables could run out of sight over the top of the side panels and into the battery compartment? Or, if I remember correctly, one of the fuse blocks in the battery compartment is modular. I added an OEM fuse holder for the fridge to the fuse block by sliding it into place.
yes...
The install of the unit is easy. There are four allen bolts behind the trim around the fridge door. They draw the unit tightly up to the bulkhead. If your car does not have the ski opening there will a knock-out panel beneath the carpet covering the bulkhead.
2013 audi fridge install
I am installing a factory audi fridge in a 2013 audi a8 and was going to hard wire it. Could anyone help with the wiring on factory plug. It has a purple,red , orange,yellow and black.
Any help is greatly appreciated
OMP
09-27-2016 09:20 AM
qezel
10-29-2007 07:38 PM
Orlando 4000S
10
03-16-2007 02:26 PM
Bimmer Love
03-13-2002 07:00 AM
