Sponsored by:
Sponsored by:
repaired the bubbled valve cover paint ?
Old 07-14-2014, 06:57 PM
awdinut's Avatar
Default repaired the bubbled valve cover paint ?
I have to have a valve cover gasket replaced, and that valve cover has the lines of bubbled paint which bugs me whenever I look under the hood. So when its off would be the time to repaint.
The paint is presumably bubbling because of corrosion under the paint, and that means the re would be some grinding out of the corroded areas. And that means the ground areas would need to be surfaced-up flush before painting.
All of which brings me to my question: what product could be used to surface the ground out spots that can withstand the heat of the engine ? I think JB Weld is good to 400 degrees, but I dont know how hot the valve covers get (question #2).
Old 07-14-2014, 08:03 PM
mishar's Avatar
I don't think there is any corrosion there. So just powder painting. Red, off course.
Mirror polishing may be the way to go. A bit of Harley look.
Old 07-15-2014, 01:06 AM
awdinut's Avatar
I think there has to be something going on with the aluminum under those strips of raised paint...why else would the paint be doing that ?
Old 07-15-2014, 05:04 AM
1Wasserwerks's Avatar
I would prefer to have them stripped, aluminum ceramic coated and then hand polish with simichrome polish. As viewed on my 90' VW GLI 16V....
Old 07-15-2014, 06:53 AM
bmwm750's Avatar
Agreed. Nice, long lasting solution.
Second choice would be powder coat.
Old 07-15-2014, 07:29 AM
mishar's Avatar
Aluminum is generally difficult to paint. Requires right primer. Temperature (not more than 90°C 194°F) doesn't help either. I think that it is just paint pealing of aluminum. Than again, if you already decided to fix it go ahead and peal a section. Be a pioneer.
Another way to do it is anodizing. Just choose a color. It's not expensive.
Old 07-16-2014, 05:24 PM
aTOMic's Avatar
Take it to a powdercoater with a good reputation in your area. They'll sandblast and coat it. I doubt the corrosion is more than "skin-deep". The powdercoat covers lots of flaws, like thick paint would. Where my paint bubbled up it's smooth beneath.
If you want it mirror-polished and clear-coated (chrome look), the best I know of is Advanced Plating in Nashville. To polish a valve cover like ours is very labor intensive, I bet $350 plus finish. But it will be PERFECT. overkill for our valvecovers. They mostly do showcars. If you go that route tell Steve Tracy (owner) I sent you. We go back. They do a LOT of online / ups work.
Anodizing will highlight every flaw I'm afraid. After a good sandblaster finishes might not be too bad.
kinderutz
Audi Original "S" Cars
21
12-28-2008 06:59 AM
RallyAudi
12
05-09-2007 04:22 AM
pac1085
11-19-2006 04:46 PM
selfproclaimedv8buff
01-15-2004 12:11 PM
Quick Reply: repaired the bubbled valve cover paint ?
