A/C Blower not Working
#11
I have an 03 a8l with the solar sun roof. Is my blower not blowing due to the solar relay switch or some other issue. I have read it could be but can't find any relays in any location that people have said it would be. Passenger right kick panel is only fuses and under dash has nothing. Where should I look? Or am I even on the right track?
#12
In all fairness, he could still be in the right place if it's a European model year. Whenever people have a solar sunroof and lose a blower around here, it does always seems to be because the blower motor went out from the extra use.
#13
Not sure which recent poster owns, but if D3 expect it is probably the HVAC blower itself from the repeated posts and then confirms by owner it was fixed with a new blower..
From having owned a 2000 C5 A6 with a solar roof that was likely similar to the D2, the blower did not necessarily fail outright but developed noises, more often when very cold (like freezing in winter). If so, replace blower. The switching relay/electronics were on the underside of the roof panel itself and you pulled the roof upholstery back that covered it to get at it. It was not sold as a separate part IIRC. You could test with a voltmeter and car in sun to see if the roof itself was outputting power at the electrical connector pins between the roof panel and the sunroof cut out opening. Explained in Bentley. On my C5 either the panel or the control board failed , and I eventually found a used parts seller who would sell me just the glass panel (with the board) and not the whole cassette/sunroof frame with it. Made shipping more reasonable. Too many years ago now to remember any more than that.
#14
Thanks everyone for input. Fuse, resister, and motor were all shot.
#15
Glad you got it fixed. You should be good for another 10 years or so.
#16
Hello,
Today is the second day my AC blower would not start after leaving my Q7 parked outside during the day. It starts fine in morning coming out of my garage but after being parked outside in the sun it shuts down shortly after starting the car. The obvious fault from VCDS "Open or Short to Plus...", can anyone help with whether this is a fuse issue on or something else? Tomorrow I am Going to pull the glove compartment to check the blower operation. Thanks in advance
1 Fault Found:
01273 - Fresh Air Blower (V2)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 42
Reset counter: 5
Mileage: 122257 km
Time Indication: 0
Date: 2016.07.26
Time: 14:40:32
Freeze Frame:
Temperature: 42.0°C
Speed: 21.0 km/h
(no units): 183.0
Load: 0.0 %
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 42
Reset counter: 5
Mileage: 122257 km
Time Indication: 0
Date: 2016.07.26
Time: 14:40:32
Freeze Frame:
Temperature: 42.0°C
Speed: 21.0 km/h
(no units): 183.0
Load: 0.0 %
Code:
Thursday,11,August,2016,19:23:42:62422 VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86 VCDS Version: 15.7.4.1 Data version: 20160216 www.Ross-Tech.com VIN: TDI S-Line License Plate: TDI -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: FE (4F0) Scan: 01 02 03 05 08 09 15 17 19 28 34 36 3C 42 46 47 4C 4F 52 55 56 5F 62 69 6D 6F 72 76 VIN: TDI S-Line 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 28-HVAC, Rear -- Status: Malfunction 0010 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4C-Tire Pressure II -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 69-Trailer -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 6F-Centr. Conv. II -- Status: OK 0000 72-Door, Rear Right -- Status: Malfunction 0010 76-Park Assist -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CATA) Labels: 059-907-401-V2.clb Part No SW: 4L2 910 401 HW: 4L0 907 401 D Component: 3.0TDI EDC17 H16 0005 Revision: 54H16--- Serial number: Coding: 2A2A4012253600050000 Shop #: WSC 08503 001 1048576 ASAM Dataset: EV_ECM30TDI0114L2910401 001005 ROD: EV_ECM30TDI0114L2910401.rod VCID: 61C98C7A70BA7C3611-8034 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels: 0C8-927-750.clb Part No SW: 0C8 927 750 S HW: 0C8 927 750 S Component: AL1000 AISIN 001 1785 Serial number: Coding: 001378 Shop #: WSC 41319 001 1048576 ASAM Dataset: EV_TCMAL991031 001001 ROD: EV_TCMAL991031_AU56.rod VCID: 3C771D0EB79871DE62-8068 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4L0-910-517-V2.clb Part No SW: 4L0 910 517 M HW: 4L0 614 517 L Component: ESP ALLRAD MK25E1 0020 Revision: 00H02001 Coding: 0103569 Shop #: WSC 31414 790 00001 VCID: 3467352E57C8B99EAA-8060 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb Part No SW: 4F0 910 852 B HW: 4F0 905 852 F Component: FBSAUDIC6 ELV H05 0130 Revision: 00H05000 Serial number: 10602901630893 Coding: 0000135 Shop #: WSC 53193 001 1048576 VCID: 2541D86AEC12D0162D-8070 Subsystem 1 - Part No: 4F0 910 132 L Component: FBSAUDIC6 EZS H03 0020 Subsystem 2 - Part No: 4F0 910 335 B Component: FBSAUDIC6 KSG H03 0020 5 Faults Found: 00191 - Passenger's Door Handle Touch Sensor (G416) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00110111 Fault Priority: 3 Fault Frequency: 22 Reset counter: 4 Mileage: 106752 km Time Indication: 0 Date: 2015.12.03 Time: 12:26:49 00191 - Passenger's Door Handle Touch Sensor (G416) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00111000 Fault Priority: 3 Fault Frequency: 6 Reset counter: 135 Mileage: 105396 km Time Indication: 0 Date: 2015.11.23 Time: 13:04:31 00193 - Rear Right Door Handle Touch Sensor (G418) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00110111 Fault Priority: 3 Fault Frequency: 108 Reset counter: 220 Mileage: 112287 km Time Indication: 0 Date: 2016.02.16 Time: 16:40:20 00191 - Passenger's Door Handle Touch Sensor (G416) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00111011 Fault Priority: 3 Fault Frequency: 9 Reset counter: 2 Mileage: 105886 km Time Indication: 0 Date: 2015.11.26 Time: 13:03:30 00193 - Rear Right Door Handle Touch Sensor (G418) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00111011 Fault Priority: 3 Fault Frequency: 55 Reset counter: 234 Mileage: 106479 km Time Indication: 0 Date: 2015.11.30 Time: 13:45:45 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: None Part No SW: 4L0 910 043 D HW: 4L0 820 043 AF Component: KLIMA 4 ZONEN H13 0050 Revision: 00---021 Serial number: 00000030158300 Coding: 0002A036 Shop #: WSC 31414 790 00001 VCID: 2541D86A2C12D0162D-8070 Subsystem 1 - Part No SW: 8K0 959 772 A HW: 8K0 959 772 Component: SLR-B8 H05 0003 Coding: 070000 Subsystem 2 - Part No SW: 8K0 959 772 A HW: 8K0 959 772 Component: SLR-B8 H05 0003 Coding: 070000 1 Fault Found: 01273 - Fresh Air Blower (V2) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 42 Reset counter: 5 Mileage: 122257 km Time Indication: 0 Date: 2016.07.26 Time: 14:40:32 Freeze Frame: Temperature: 42.0°C Speed: 21.0 km/h (no units): 183.0 Load: 0.0 % ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 AC HW: 4F0 907 279 C Component: ILM Fahrer H28 0360 Revision: 00000000 Serial number: 4F0907279 Coding: 0133123 Shop #: WSC 31414 790 00001 VCID: 6ADBEB56458C3F6EC0-803E Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB Component: Wischer AU716 H17 0100 Coding: 00064792 Shop #: WSC 31414 Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH04 0003 Coding: 00150059 Shop #: WSC 31414 1 Fault Found: 02746 - Bulb for Daytime Running Light; Right 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 2 Fault Frequency: 50 Reset counter: 0 Mileage: 112176 km Time Indication: 0 Date: 2016.02.11 Time: 17:38:00 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4L0-910-655.lbl Part No SW: 4L0 910 655 A HW: 4L0 959 655 B Component: 73 AIRBAG AUDI8RH43 0230 Revision: 07H43000 Serial number: 0038QD09H4MG Coding: 0014131 Shop #: WSC 31414 790 00001 VCID: 2B552E528AF6E666FB-807E Subsystem 1 - Part No: 4L0 910 339 A Component: BF-Gewichtsens. H03 0030 Subsystem 2 - Serial number: 6332QSME4F6D0908U Subsystem 3 - Serial number: 6342QSME506D4208E Subsystem 4 - Serial number: 6352QSME1967433CM Subsystem 5 - Serial number: 6362QSME4F6A1A22S Subsystem 6 - Serial number: 63734SME725F1038% Subsystem 7 - Serial number: 63834SME33623604T No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Cannot be reached ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb Part No SW: 4F0 907 468 Q HW: 4F0 907 468 G Component: GW-BEM 5CAN-M H06 0047 Revision: MB300033 Serial number: 3300M106268232 Coding: 00C303 Shop #: WSC 31414 790 00001 VCID: 3D71100AA48278D655-8068 Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D Component: J367-BDM H07 0125 2 Faults Found: 03041 - Energy Management Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 2 Reset counter: 223 Mileage: 121512 km Time Indication: 0 Date: 2016.07.20 Time: 11:23:23 Freeze Frame: Bin. Bits: 10111 Voltage: 11.20 V Count: 7 02256 - Quiescent Current 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 7 Fault Frequency: 2 Reset counter: 243 Mileage: 122294 km Time Indication: 0 Date: 2016.07.27 Time: 01:45:00 ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4L0 910 158 HW: 4L0 919 158 AA Component: KLIMABETAETIGUNGH06 0060 Revision: 00---010 Serial number: 00000000242604 Coding: 0000006 Shop #: WSC 31414 790 00001 VCID: 68DF915E5B800D7ED6-803C 1 Fault Found: 01320 - Control Module for Climatronic (J255) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 2 Fault Frequency: 2 Reset counter: 181 Mileage: 120749 km Time Indication: 0 Date: 2016.06.28 Time: 15:00:03 Freeze Frame: ON ------------------------------------------------------------------------------- Address 34: Level Control Labels: None Part No SW: 4L0 910 553 J HW: 4L0 907 553 Component: LUFTFDR.-CDC H03 7860 Revision: --H03001 Serial number: 15.1528-0122.2 Coding: 0015520 Shop #: WSC 31414 790 00001 VCID: 31693C3AA8DA8CB6C1-8064 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None Part No SW: 4F0 959 760 D HW: 4F0 959 760 D Component: MEM-FS H08 0064 Revision: AA000000 Serial number: 00001002021541 Coding: 00581B00000011110000 Shop #: WSC 31414 790 00001 VCID: 326B33366DDCB7AEB8-8066 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change Labels: None Part No SW: 4L0 910 566 C HW: 4L0 907 566 B Component: J0769_SWA_MasterH01 0050 Revision: 00H01000 Serial number: 6PZ 009 014-10 Coding: 0010001 Shop #: WSC 31414 790 00001 VCID: 2E532746B9E4934EDC-807A Subsystem 1 - Part No: 4L0 910 568 C Component: J0770_SWA_Slave_H01 0050 Subsystem 2 - Serial number: 6PZ 009 014-30 Subsystem 3 - Serial number: 5F29.07.1000H010003C911121ÿ Subsystem 4 - Serial number: 911121ÿ No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb Part No SW: 4F0 959 793 T HW: 8K0 959 793 M Component: TSG FA H12 0357 Revision: Serial number: 0004000126239 Coding: 011F57205E40440004 Shop #: WSC 31414 790 00001 VCID: 489F71DEFB402D7EF6-801C 1 Fault Found: 01705 - Selection Switch for Mirror-Adjust (E48) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 2 Mileage: 123099 km Time Indication: 0 Date: 2016.08.10 Time: 17:20:00 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4L0-910-289.lbl Part No SW: 4L0 910 289 H HW: 4L0 907 289 H Component: Komfortgeraet H10 0110 Revision: 0110 --- Serial number: 01325853220000 Coding: 3569693 Shop #: WSC 31414 790 00001 VCID: 3561082A5CB2A0969D-8060 Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H05 1501 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: None Part No SW: 4L0 035 466 A HW: 4L0 035 466 A Component: BO Q7 H30 0110 Revision: 05S00000 Serial number: 01504100004818 Coding: 0D000001 Shop #: WSC 31414 790 00001 VCID: 2959D45A400AF47609-807C Subsystem 1 - Part No SW: 4L0 910 465 A HW: 4L0 035 465 Component: BO Q7 SLAVE H41 0780 No fault code found. ------------------------------------------------------------------------------- Address 4C: Tire Pressure II Labels: 4F0-910-274.clb Part No SW: 4F0 910 274 B HW: 4F0 907 274 Component: J793 RKA+ H03 0110 Revision: 00000276 Serial number: 00002760010860 Coding: 0758733 Shop #: WSC 31414 790 00001 VCID: 2345C672E2262E2643-8076 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 D Component: ILM Beifahrer H14 0100 Revision: Serial number: 00000000070545 Coding: 0012001 Shop #: WSC 31414 790 00001 VCID: 5EB3B78689C443CE2C-800A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Cannot be reached ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4L0 910 357 B HW: 4L0 907 357 B Component: AFS 1 H01 0010 Revision: 00000001 Serial number: Coding: 0000032 Shop #: WSC 31414 790 00001 VCID: 2B552E528AF6E666FB-807E Subsystem 1 - Part No: 7L6 941 329 A Component: AFS-Modul links H07 0004 Subsystem 2 - Part No: 7L6 941 329 A Component: AFS-Modul rechtsH07 0004 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- VCDS Release 15.7.4: SRI Reset Control Module Part Number: 4L0 920 984 A Labels: 4L0-920-xxx-17.clb Component:KOMBIINSTR. H10 0209, Coding:8BD664040901CF05020201 Operation: Please select an operation ************************************************************************************************************************ Channel Description Unit Current val. New val. 02 Service Reminder Status 2 --- 40 Distance since Service km x100 96 --- 41 Time since Service Days 155 --- 42 Minimum Distance to Service km x100 100 --- 43 Maximum Distance to Service km x100 100 --- 44 Maximum Time to Service Days 365 --- 45 Oil Quality 1 --- 47 Soot Quantity DIST x100 208 --- 48 Thermal Load DIST x100 109 --- 49 Minimum Time to Service Days 365 --- 50 Basic Distance Value for Oil Change km x100 100 --- 51 Basic Time Value for Oil Change Days 365 --- 52 Basic Distance Value for Inspection km x100 100 --- 53 Distance since Inspection km x100 96 --- 54 Basic Time Value for Inspection Days 365 --- 55 Time since Inspection Days 155 --- 56 Day Counter Days 2186 --- ************************************************************************************************************************
#17
Sounds to me like the blower motor needs brushes. Time to either change the brushes or change the motor.
#18
Follow-up on this issue, after a week of working fine, the blower motor started doing the same thing (turning off after coming online), end up replacing the blower motor with a new one (Amazon - TYC 700262 Replacement Blower Assembly).
aubiexx
Q7 MK 1 Discussion
11
09-12-2016 06:50 AM
colorado coupe
11-10-2014 09:32 AM
soccaplaya6996
05-13-2005 06:13 PM
